Garmin 1030 Battery
MudLark
Hi guys,
My Garmin 1030 battery has started swelling and lifted the screen although it otherwise works entirely normally. I simply can't find a replacment battery anywhere locally and importing is impossible with the regulations around shipping lithium batteries. But I have found someone who thinks they may well be able to repack the battery for me - they do it for a lot of devices. Certainly a lot cheaper than a new device and the unit is going to useless anyway without a functioning battery. Anyone tried this repacking option and if so, what has the experience been?
Any other options for sorting out the battery issue short of replacing the device?
Link to comment
Share on other sites
For some reason, Makro online is advertising Garmin replacement accessories, including batteries, I haven't quite figured out how to match their numbers to the Garmin product numbers, I'm sure if you have the specs of the battery you can come right. Below link as an example.
https://www.makro.co.za/electronics-computers/navigation-accessories/gps-navigation-systems/gps-accessories/-cameron-sino-replacement-battery-for-compatible-with-garmin-361-00019-02-ia2b309c4b32-/p/f853c15f-69ba-4f13-bbaf-d4ebd455bc0c?gad_source=1&gclid=Cj0KCQiAzoeuBhDqARIsAMdH14HkVKNv4ORiWL_0HEHcoTRJKwk-bO80-JZUo4lChZPf0e-kCo8wqBcaAv2dEALw_wcB
Link to comment
RC and robotics shops stock batteries that will fit. Just pop the current one out and measure it (there are many instructions on the interwebs), then find one that fits and splice it in.
@phenning did it with his 130 not too long ago, a quick search will turn up the thread here.
Link to comment
Thank you. I have seen those but cannot identify a compatible one. Problem is that they also not avilable in-store so I can't go and compare items either.
Link to comment
Thanks Droo. I might have to do this as well in the end. Wife might be on a trip to the UK shortly though so possibly also could get one there for me,
Link to comment
6 hours ago, MudLark said:
Hi guys,
Garmin will replace it. It will just take about  3 weeks if you need it posted back to you.
if you In jhb you it might be quicker turn around
Link to comment
Thanks Diesel. I live just around the corner from them so will check it out. In the past all battery issues with Garmin have been 'buy a new one at a discount' and the discount basically takes you to the same price - or just a bit under Easy Bike. But maybe that's my best option anyway. Will contact them.
Edited by MudLark
Link to comment
If you can get inside the unit Just pop the plastic with a pin.  I do it to RC Helicopter batteries and they work normal after. Don't Know about Garmin Batteries but it should be the same technology.
Link to comment
If you’re saying to pop the swollen battery with a pin, then that is incredibly bad advice. My team deals with dozens of device battery changes a day, but we have a protocol that kicks in with swollen batteries that requires special handling, packaging and shipping rather than dealing in house with them as the risks are very high of a thermal event. If I’ve misunderstood your advice, apologies and ignore the above but sticking a pin into a swollen lithium ion battery is not something to ever do.
Link to comment
Thanks Diesel. I went to see them and it looks like they might well simply replace the unit with a new one - or possibly against a relatively small contribution. Looks like the option that might make the most sense for me.
Link to comment
I have read other sites suggesting popping the battery. I am doubtful of the wisdom. If all.else fails, I will have the battery repacked.
Link to comment
You can’t, it’s a single cel lithium polymer. If you pop it you risk shorting it out and that means it will go whooosh.
just replace it if you can get  into the unit
Link to comment
You definitely can.
You really shouldn't, but you can.
Link to comment
Please please please don't pop a Lithium battery because someone on the internet said so. If you have a thermal event, you will *** bricks. We've had a few over the years and that's in a controlled environment. I would hate to have one at home.
Link to comment
Well, that could get exciting.
Link to comment
@BigDLYou don't stick a pin into the battery. The LI-Po Batteries on the RC Helicopters Are Packed in Plastic and they get a Build Up of Gas Inside the Plastic Packaging You just pop the Packaging not the Battery. If You Stick anything into the Battery it Could Go UP in Flames. In the Picture I show one that's been Popped and still works perfectly.
Edited by dasilvarsa
Link to comment
