How do I check whats the maximum chainring my bike can fit. I ride a mtb, but now and then do road races, but no enough to go and buy a road bike. I want to get a bigger chainring fir road races, but dont know if it will fit my bike
Edited by Reinardt van Heerden
People requesting photos
How long is a piece of string! Without the knowledge of what bike and maybe a few pictures no really possible to say. Not being rude. You will probably also have to use a longer chain.Β
if the cassette is smaller the chain ring can be bigger without changing the chain. Although, the cassette and chain would need to be compatible.
Most mtb's only accept up to a 38T without a chainline adjustment. So if the cassette is smaller the chainline can be combobulated a wheee bit to allow for maybe a 40T
3 hours ago, RobynE πŸš΅β€β™€οΈ said:
Show us a pic of what you’ve got.Β
Bigger ring will also need longer chain and your gears will need to be tweaked so it’s not quite plug n play.Β
No problem, its about the clearance with the frame
There's room for a 38T provided you don't have any chain suck. Larger chain rings may rub when you're cranking on the power as the stays and down tube flex. A 40 may fit if you reduce the chainring offset by 3mm and reduce the cassette sprocket size
