30 min power to weight is a function of threshold power (60 mins) - the %age of FTP would vary from rider to rider but could be around 107%
A 17 year old rider Elite rider may well have a power to weight at threshold of around 4.5-5 w/kg and so 4.8 - 5.3 for 30 mins.
This is really all rough estimates and needs to be treated as such - more info needed to be of any real use to you.
I got this form UCT's sports institute :<?:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
* Normal body fat% range for elite male athletes (pre-competition):  8 ? 12%
* Normal body fat% range for well-trained male athletes: 10 ? 14%
* Normal body fat% range for active men: 12 ? 18%
* Sum of skin folds for elite male endurance athletes < 40 mm
* Sum of skin folds for male endurance athletes < 70 mm
* Peak power output for elite cyclists ranges from 400 ? 550 W
* Power to weight ratio for elite cyclists ranges from 5.5 ? 7 W/kg
* VO2max   for sedentary men ~ 40 ? 50 ml/kg/min
* VO2max   for active ? well trained men ~ 50 ? 65 ml/kg/min
* VO2max   for elite cyclists ~ 68 ? 85 ml/kg/min
Hope that helps!
[/Quote]
They mean threshold power surely? Peak power (5s) should be well up in the 1500 plus range.
Peak Power (PPO or MAP) is the result of a ramped test of ever increasing power over time(there are several protocols) that lead to the peak power that is sustained for the last ramp being measured - this is where Marius' figure comes in.
Heard from one of the commentators with the Tour De France that Tom Boonen's watts output in a spint is 1800 for the last 20 sec's.Is that true
[/Quote]
So that would correspond to power at VO2Max?
