from http://www.velonews.com/article/81107
Shimano's electronic Dura-Ace
Posted Aug. 1, 2008
Article Extras
Photos
Shimano has formally announced plans to release Dura-Ace Di2, a new electronic shifting option for the all-new 7900 series Dura-Ace, in January.
Comprised of dual control shift/brake levers, front derailleur, rear derailleur, a wiring harness and battery pack, the new Dura-Ace Di2 7970 components integrate with components from the upcoming 7900 series Dura-Ace group, while adding a total of only 68 grams.
Electrically-actuated shifting eliminates cable friction and contamination. The shifters are now merely switches, which also allows for creative placement of optional remote shifters while also reducing the weight and profile of the main shifting units. For example, a rider could place remote switches out on the ends of aero bars as well as on the top of drop bars near the stem.
Derailleur movements are computer-controlled and servo motors in both front and rear derailleur create synchronized shifts.
http://www.velonews.com/files/images/ST_7970_01.Thumbnail2.jpg
The Di2 shifter: Lighter and sleeker profile
ST-7970 Dura-Ace Di2 Dual Control Levers
By eliminating mechanical shifter parts and using unidirectional carbon fiber brake lever blades, the new Dual Control lever is 155g lighter than the mechanical version. The levers are slimmer, and the ergonomics are further refined for a comfortable grip.
Wiring Harness
Except when it comes to downloading the on-board computer to a PC, the system is not wireless. It powers each derailleur through a wiring harness rather than adding the complexity of wireless transmitters and receivers. To have been wireless, each component would have required a separate battery, which would have added weight, and each receiver/transmitter would have consumed battery life at a higher rate.
The shifter wiring harness accepts an all-new FlightDeck computer (SC-7900). The new FlightDeck features heart rate, altitude, grade, cadence, estimated caloric consumption, gear position, and battery life and is directly downloadable data via a wireless connection.
http://www.velonews.com/files/images/RD_7970.Thumbnail2.jpg
The Di2 rear derailleur doesn't look like those on older electronic systems.
RD-7970 Dura-Ace Di2 Rear Derailleur
Like the 7900 mechanical derailleur, the 7970 has a new carbon fiber rear pulley cage, and the new design is compatible with wider-range cogsets, accommodating up to 27 teeth. Driven by a servo motor instead of a cable and spring, shifts are identical and precise due to the computer control unit analyzing each shift.
The rear derailleur has a similar profile to standard rear derailleurs, rather than incorporating an oversized housing containing a reciprocating notched bar driven by the upper jockey wheel, which provided shifting power for Zap and Mektronic. Already less vulnerable due to its shape, Shimano built a mechanism into the rear derailleur that allows it to move inward under impact to reduce the potential for damage in the case of a crash. After being bumped inward, cycling through the shifting a couple of times automatically re-synchronizes the shifter and rear derailleur.
http://www.velonews.com/files/images/FD_7970.Thumbnail2.jpg
The Di2 front derailleur is the brains of the operation
FD-7970 Dura-Ace Di2 Front Derailleur
The front derailleur is the ?brains? of the system. This is a departure from Mavic Zap and Mektronic systems that preceded it; these had cable-actuated front derailleurs. The integrated ultra-compact CPU not only ensures shifting precision for both the front and rear derailleurs individually, but also monitors the position of each. The front derailleur tracks the chain and requires zero manual trim while maintaining shifting speed. The front derailleur logic also performs the inward shift from the big chainring in two split-second movements to eliminate chain drop.
SM-BTR1 Dura-Ace Di2 Battery Pack
The 7.4V, high performance Lithium Ion battery is designed to deliver reliable, long life even in the worst conditions. In conditions requiring consistent and frequent shifting, the battery is capable of 1000 kilometers of use. That?s not much relative to the battery life in a bike computer, but fortunately, this battery is rechargeable. Lithium Ion technology is lighter, more compact and better performing than other battery types.
Shimano Dura-Ace Di2 7970 Specs
Unidirectional carbon fiber lever blades reduce weight without loss of durability
Shifting positions mimic Dual Control with the ease of an electric switch
Titanium clamp and fixing bolt
Enhanced perch shape is more comfortable over longer distances
Integrated reach adjuster provides a custom fit for even smaller hands
Shift impulses transmitted in fractions of a second
Revised brake cable pivot location provides better braking modulation
Optional satellite shifter
Wiring harness is FlightDeck ready
255g
Carbon fiber rear pulley cage for lighter weight without loss of durability
New geometry allows for use of 27 tooth max cog
Servo saving feature allows derailleur body to move inward on impact to reduce or eliminate damage to the component and servo motor
225g
Integrated CPU monitors both front and rear shifting for precise and consistent derailleur alignment
Computer integration allows the front derailleur to track the chain eliminating the need for manual trim and also eliminates chain drop when shifting inward from the big ring.
124g
http://www.velonews.com/files/images/SM_BT79_side.Thumbnail2.jpg
The lithium-ion battery pack holds a 1000-kilometer charge
High performance Lithium Ion composition
Rechargeable (1.5 hours for full charge)
Mounting bracket to easily adapt to most bikes
Approximately 1000 kilometers of heavy use between charges - 7.4V
68g
SC-7900 Flight Deck Cycle Computer
Gear indicator with virtual cadence
Heart rate monitor
Estimated caloric consumption
Altitude & inclination
Battery life indicator
Wireless PC connection
Mampara2008-08-01 05:14:12
  • Replies 46
All looks and sounds good, BUT I'm not convinced that the reliability issue is equal to or better than what the current cable / spring operated systems offer.
Call me negative but I think I'll stay with cables and springs a bit longer.
1. SM-BTR1 Dura-Ace Di2 Battery -
Something else that can go wrong and relies to much on human factors influence (i.e. remeber to charge the damn thing).
Bicycles are now going to become less enviromentaly friendly...
2. Integrated CPU monitors both front and rear shifting for precise and consistent derailleur alignment
Yeah and when the CPU goes PUC (pronounced puke) what then?
3. The front derailleur is the ?brains? of the system.
But I prefer to be the brains...
4. Shifting positions mimic Dual Control with the ease of an electric switch
Electric switches never fail... dont they not?
5. Driven by a servo motor instead of a cable and spring, shifts are identical and precise due to the computer control unit analyzing each shift.
Servo motor... computer....  More parts that are unlikely to ever fail while your still at home that is
6. Wiring Harness
We just got rid (well almost) of wires from bike computers now there's going to be even more of them, imagine if one of these wires gets damaged in a fall or something, there goes your signal to the servo thats going to change the gears on the next uphill.
I'm guessing you all missed Berghardt's problems in the Tour ?
His gear got stuck in 53x11 while in the break and he ahd to go over some steep climbs out of the saddle for a while before he could get a new bike......
and he has maechanics to look after him
gianni2008-08-01 13:29:28
  Quote
It was the evil fandacious disguised as Elvis with a Shimano remote.
  Quote
Imagine forgetting to recharge while battling a steep hillConfused
that is exactly what happened to one of gerolsteiners riders in the tour during the alpe du huez stage!!!!!
I'm quite happy with mechanical shifting. Can't see how electronic is going to improve my cycling experience that much more. All I see is more things to go wrong. I can't see this becoming the norm and just wish Shimano had rather spent the R&D time and money on developing a more affordable power meter system.
  Quote
FYI he was on the 7800 mechanical Dura Ace....
