It's finally here....the Chris King BB
After literally years of rumours and the project being shelved as they waited for the industry to settle on a design, Chris King have finally introduced their much-anticipated bottom bracket.
It won't be cheap with pricing similar to their basic headset, but it will come with the same 5 year warrenty, user servicable bearings and a grease injection tool.
MintSauce2008-09-26 01:17:17
Very nice indeed...If it will cost in the region of the headset its actually a bargain. With the 5 year warranty they should outlast shimano and raceface by a mile.
Would like to see it from upclose.
There was a video on MTBR last night showing the grease injection tool in action. Video seems to have disappeared though.
You have to remove the crank which is a bit of a mission, but not that serious considering you won't be doing it THAT often.
It's the same diameter as the spindle and slides into the cup....give it a few pumps and that's it. As with most similar applications, the new grease forces out the old grease which is then simply wiped off. Flippen brilliant!
The greaseing tool.
http://www.cyclingnews.com/photos/2008/tech/shows/interbike08/interbike082/Chris_King_BB_grease_injector_ports.jpg
http://www.cyclingnews.com/photos/2008/tech/shows/interbike08/interbike082/Chris_King_BB_grease_injector_in_action.jpg
The greaseing tool.
ah, yes you can. cool.
will be a bit smutty, same as those nais old shimano and campag hubs, but it has some style and the lifespan should be looooooong.
No grease into the BB in my workshop . Grease and muddy water makes for the best grinding paste you can find . But CK must have done a lot of research on this and time will tell and a 5 year warranty counts for a lot . Carbon caps !!!! Don't think so .
No grease into the BB in my workshop . Grease and muddy water makes for the best grinding paste you can find.
Hey Ou Ballie....the new greases forces out the old grease and any crap in it. Klim onder daai klip uit!
