  • Replies 73
They are light, works okay, but I dont think is very durable. Dont buy the brake calipers if you are heavy. I weigh 70kg and could feel the diffrence in breaking power when I changed to KCNC.
I've only used the road brake calipers, so cant comment on the other parts.
Yes, the brakes aren't all that. I have a set and as much as they look cool, they don't work as well as they should. Having said that I can't complain about the machining, seems well made.
people will tell you the skewers stretch(Bull$H!T)
they will also tell you the brake calipers walk on your rim(yes if you weigh more than 70 or you weigh less than 70 but decide to hit anchors going at 80 without a gradual pull of the lever)
then come the jockey wheels ok have not tried them but from what i have heard they are good as any dura ace fsa and campy jockey wheels
in my opinion its money well spent on all of thier stuff and not hellishly xpensive if they do break
I have stems, bars, skewers ,jockey wheels and seat post.
Never had a problem with any of their stuff.
I'm heavy so I havent used their Brake calipers.
The skewers are really light, but came apart after 6 months (luckily not while I was riding!)
I had the valve extensions which didnt come with the oh-so-important O-rings, but i sourced these elsewhere. Didnt matter though, they machined down the end of the aluminium tube so narrow to save weight that my pump doesn't "grip" on it, and had to toss them anyway...
I bought the road calipers less than a year ago and initially found that they were not as good as my dura ace ones, but maybe it was just because they felt a bit different. I kept them on for a while longer and found that they got better as time went by, dont know if its just because I got used to them or they just needed breaking in (pun intended Wink). They do stop very well, and I am 78kg's.
As far as the other parts go - the brake pads are crap.
The skewers are good - have 2 sets 44g weight for road (training rims and racing rims)
The cassettes are superlight but are crap - only last about 1000 km's even with the kcnc chain - no personla experience here but was told this by the kcnc dealer at the Argus Expo in 2008
Crankset - no idea but it looks nice
Bling bolts - same as any other
dougaroony2009-01-27 08:07:55
It's good value for money and durable. Calipers came with a very low-spec pad. Local changed it and since then there's no difference between DA and KCNC. I know riders who weigh over 100k's who race them. The bolts, and other bits are strong and do what they are supposed to. Handlebars are lighter than carbon, without the doubt issues.
Do it.
My skewers on my MTB has done thousands of kilometers and no problem.
I had a terrible creak on my bike, it drove me nuts at the 24 hour, turned out to be the crank bolts, took them out greased them a bit and all good.
I think the KCNC products are worth it, their really cheap compared to products like Ritchey,Hope ect their not the same quality but you get them at less than half  the price, just don't try and ride across America too often with them.
i know Token do some light weight breaks, they weigh about 210g and look alot strong, i am expecting to get a set soon so will be able to tell you what they are like
I got the jockey wheels,bolts and skewers,
the skewers does come apart after sometime but that could be because i take my rims off the frame as i dont have a bike rack so i load them in the boot or the back seat.guess its not that durable.
The jockey wheels no complaints so far other than the paint starting to come off.
the bolts are pretty good i think,i really cant see a diff other than bling bling only.
