Spinnekop Posted June 19, 2007 Posted June 19, 2007 Hi all. Here are the choices. Budget is limeted and thus the above choicesNovice rider trying MTB outWhat warranty has the above two manufacturersLockable shock that important?Thanks for all the replies and advice!!!!!
Mudsimus Posted June 19, 2007 Posted June 19, 2007 Trek's got a lifetime warranty for the first owner.
nellie Posted June 19, 2007 Posted June 19, 2007 Silverback. Also have the Alpine - it comes out with a lockout(lackable...whatever) shock - nice gadget and lovely to play around with. Some people swear by lockout shocks, some say it's a waste - personally i like it. I'd say it's a comfy enough ride (when considering the price), shock's not too bad, Alivio groupy does it's job without hassles. Quite a decent frame that's not too expensive and it's light enough. Great breaking innitially...but wears out after a little while...so might just want to check that or upgrade it after some time. Hope it helps.nellie2007-06-19 09:35:27
nellie Posted June 19, 2007 Posted June 19, 2007 You're welcome - seems like you've got a tie in the poll though.
Frosty Posted June 19, 2007 Posted June 19, 2007 My 2c worth... I borrowed a Silverback (not sure what make) for the Magalies Monster and Sabie Shenanigan. It was basic as basic came: V-brakes, no lockout, hard-tail, 8 gears, etc, etc. I managed fine with it - in fact I finished in 25th place on the Shenanigan - had more to do with my (road) fitness/strength than technical ability. The only problem I had was shifting - the rear derailer worked opposite to what I was used to (if the cable were to break, the derailer moves up to the granny gear). For R2770 I would ride the Silverback. If, one day, I decide that MTB is not my thing, then I haven't wasted too much cash. If I decide that MTB is my thing, then I can always look for a more expensive/appropriate bike.Frosty2007-06-19 09:49:30
Hendrik Petoors Posted June 19, 2007 Posted June 19, 2007 Nellie Brieke behoort nie slegter te word nie. Hou die briekpads skoon en haal garras daaruit. Dit help om hulle liggies op baie growwe skuurpaier te "skrop" ...... onthou nie skuur nie !!!!!!! of gebruik een van daai fyn tandjie messe en krap die briek oppervlakte daarmee. Dit maak grof en haal ook sommer die fyn stukkies yster en goed uit wat die rim kan krap. Onthou jy hoef gewoonlik nie die pads uit te haal nie. Clip net die lang springs op die arms los, die briekkabel los en die arms beweeg uit wat jou genoeg spasie gee om daar te werk. ONTHOU NET OM HULLE TERUG TE CLIP WANT JY KAN NIE BRIEK SONDER HULLE NIE!!!!!!!! Maak ook die briekoppervlakte op die rim skoon. Mavic maak 'n uitveer wat baie duur is maar jy kan sommer 'n Scotchbrite pad gebruik om die oppervlakte skoon te maak as dit baie vuil is. Weereens moet nie skuur nie!!!!!!!. Vryf net liggies en probeer om die Gunk weg te kry en nie die aluminium te skuur nie. As jy die briek oppervlaktes gereeld skoonmaak sal die skuurdery hierbo nie nodig wees nie. Kyk ook na briekblokkies. Ek het BBB se Vee Stop triple colour pads op albei ons tandems gebruik. Gebruik die cartridge tipe. Dit werk goed. Gaan kyk by die link.... http://www.bbbparts.com/products/bike_parts/brakes/roadbrakeshoes/bbs01.html Lekker briek!!!!!!
shaunh Posted June 19, 2007 Posted June 19, 2007 Spidey, for a few hundred rand (if you enter more than once to increase your chance of winning), you could win a complete MTB gruppo including wheelset. All you will then need is a frame with bars and a seat!Enter and win!!!
Hendrik Petoors Posted June 19, 2007 Posted June 19, 2007 Spidey op 'n Trek nooit!!!! Hy hou minder van hulle as Shimano!!!!! Dit MOET vir iemand anders wees, hy darem al die Epic op 'n fiets met 'n halwe shock gedoen so hy is darem nie meer die novice in sy Poll nie!!!!!!!
Spinnekop Posted June 19, 2007 Author Posted June 19, 2007 Spidey op 'n Trek nooit!!!! Hy hou minder van hulle as Shimano!!!!! Dit MOET vir iemand anders wees' date=' hy darem al die Epic op 'n fiets met 'n halwe shock gedoen so hy is darem nie meer die novice in sy Poll nie!!!!!!![/quote'] Vir 'n vriendin Oom. Sy wil begin en kyk hoe voel dit.....
nellie Posted June 19, 2007 Posted June 19, 2007 Dankie oom H!! Sal daai probeer...oom is 'n ster!Die briekblokkies was 'n bietjie deur - maar die brieke SELF het klein bietjie moeilikheid gegee. Moet dit nog vir 'n diens vat een of ander tyd.
Hendrik Petoors Posted June 19, 2007 Posted June 19, 2007 Onthou om brieke te olie op die pivot punte. Eerder gereeld as eenkeer en te veel olie. Ek gebruik sommer ligte olie (masjien oilie wat in die tuit botteltjie kom) en gebruik 'n dik spuitnaal waarvan die skerp kant afgevyl is. Suig olie op hierin en drup so paar druppletjies olie op die gedeeltes wat beweeg. PASOP VIR TE VEEL WANT OLIE OP DIE PADS IS DISASTROUS!!!!!!!! Maak seker jou briekkabels is nie droog nie en maak seker beide van daai langs springs wat ek netnou van gepraat het, het dieselfde drukkrak in hulle. As hulle uitgehak is soos ek netnou gese het sonder om die briekkabel uit te haak moet altwee ewe veel gebuig wees. So ongeveer 30 grade vanaf horisontaal. Ek is seker Stadige Faantjie sal maar te bereid wees om te help. Met fatty daar sal hy ook sommer iets leer.
nellie Posted June 19, 2007 Posted June 19, 2007 Hahaha! Ek sit in WOrcester oom...sal maar my fiets vat na die oom by wie ek dit gekoop het - hy't ges? hy skuld my nog 'n free diens, so als is reg - ek gaan sommer daar agter in die workshop gaan sit en kyk wat hulle als doen sodat ek ook ietsie kan leer. Wil nie die repairs self doen nie(mens weet nooit wat 'n blond aan 'n fiets kan doen nie), maar sal defnitief oom se raad volg met die maintenance daarna!
Hendrik Petoors Posted June 19, 2007 Posted June 19, 2007 Leer maar wat hy doen. 'n Blond langs die pad met 'n stukkende fiets is deesdae NIE veilig nie!!!!!!!! Veral nie as Stadige Faan in die omgewing is nie. Weet jy my Swaer se Seun was een van die projekbestuurders by daai casino en winkelsentrum daar langs die N1. Ek dink hy is nou weg daar. Rainbow Construction dink ek???????
nellie Posted June 19, 2007 Posted June 19, 2007 Ek sal ja - het al vrek baie by ou Patric in daai workshop geleer! Ag nee wat...ons het nie sulke snaakse kreature hier in Worcester nie...almal is klub mensies en hulle is baie oulik en behulpsaam as mens gaan staan. Moet omtrent baklei as ek MY EIE wiel wil regmaak as - hulle gryp dit al amper voor ek van die fiets af is!!!Uhm...nou nie so mooi seker van Rainbow construction nie...maar hier's 'n Rainbow Chickens(ja - waar al die arme hoendertjies op Woolies en PnP se rakke vandaan kom) en sover ek weet was dit Murray & Roberts wat die Winkelsentrum gedoen het...kan nie vinnig dink wie die Casino gedoen het nie
peloton Posted June 19, 2007 Posted June 19, 2007 The lockable shock is handy for onroad application - but not so much for offroad - but is completely unneccessary imo. For a novice starting out the framebrand & groupset are not important aspects, but proper bikefit is. Make sure the bike fits, and you'll have a happy rider. The bike with the better fit should be the natural choice. Nothing wrong with the Silverback. Then again, nothing wrong with that Trek!
Register a new accountSign in
