Different people gave me different answers on this one. If you want to fit 10spd chainrings with a 9spd groupset, what chain should you fit, i.e. will a 10spd chain work with the 9spd casette as it is, or do you need to replace the casette (or spacers), or do you use a 9spd chain?
Kobie why would you want to use a 10 speed chain on a 9 speed drivetrain. I may be corrected but I doubt if it would work, The width of the sideplates is smaller than an nine speed. I think te chain may jam. Also what I well know is that you cannot use a nine speed on a ten speed. This will definitely jam. Most cassettes are riveted and only the smaller sprockets have spacers.
Kobie.
Best advice I can give is to take the plunge and get a 10sp groupo.  You can get something from about R3.5k and up which it not that bad.  That way you know you will not have issues!
Good luck
I was building a bike for my son a little while back and somehow got chains mixed up. Had a 10 spd chain on a 9 speed groupset and it made a hell of a racket from the cassette and gear changing definitely wasn't lekker. Changed the chain to a 9 speed and it solved the problem. So I would say that if you really need to mix then you should use a 9 speed to match the cassette - but the front deraileur / gear change might not be too smooth.
My 9sp chainrings were shot and I bought 10sp chainrings on the hub. My 9sp casette is relatively new, so no need to replace. I asked the question because the chain kept on slipping in between the rings when changing from big to small. 9sp Chain works 100% if you put the rings on right way around.
Kobie. A 10sp chain works better than a 9sp chain on a 9sp drive train. Shifts are smoother and quicker so you can just replace the chain with a 10sp one.
