Race:
         Duration:      2:38:33
          Work:           2290 kJ
          TSS:            196.6 (intensity factor 0.863)
          Norm Power:          293
          VI:               1.22
          Distance:      98.181 km
                             Min     Max    Avg
          Power:         0        838    241    watts
          Heart rate:    96      175    154    bpm
          Cadence:     29      188    73      rpm
          Speed:         0        75.6   37.2   kph
          Pace             0:48   0:00   1:37   min/km
Split the bunch:
          Duration:      3:47
          Work:           92 kJ
          TSS:            9.6 (intensity factor 1.237)
          Distance:      1.639 km
                             Min     Max    Avg
          Power:         140    720    404    watts
          Heart rate:    137    171    165    bpm
          Cadence:     56      86      73      rpm
          Speed:         22.2   31.2   25.9   kph
          Pace             1:55   2:42   2:19   min/km
Couple of tests - see who had legs:
          Duration:      1:50
          Work:           40 kJ
          TSS:            4 (intensity factor 1.145)
          Distance:      934 m
                             Min     Max    Avg
          Power:         75      735    368    watts
          Heart rate:    165    173    170    bpm
          Cadence:     45      96      72      rpm
          Speed:         23.4   38.7   30.8   kph
          Pace             1:33   2:34   1:57   min/km
Final Attack:
          Duration:      2:38
          Work:           68 kJ
          TSS:            7.9 (intensity factor 1.345)
          Distance:      1.664 km
                             Min     Max    Avg
          Power:         139    838    430    watts
          Heart rate:    153    175    170    bpm
          Cadence:     39      105    78      rpm
          Speed:         28.4   50.5   38.1   kph
          Pace             1:11   2:07   1:35   min/km
Peak 1min (548 watts):
          Duration:      1:00
          Work:           33 kJ
          TSS:            4.9 (intensity factor 1.703)
          Distance:      608 m
                             Min     Max    Avg
          Power:         218    838    548    watts
          Heart rate:    153    175    167    bpm
          Cadence:     66      105    82      rpm
          Speed:         28.7   40.6   36.2   kph
          Pace             1:29   2:05   1:39   min/km
Peak 10min (341 watts):
          Duration:      10:01
          Work:           205 kJ
          TSS:            20.2 (intensity factor 1.099)
          Norm Power:          374
          VI:               1.1
          Distance:      5.041 km
                             Min     Max    Avg
          Power:         0        720    341    watts
          Heart rate:    125    173    164    bpm
          Cadence:     41      106    73      rpm
          Speed:         21.7   51.7   30.1   kph
          Pace             1:10   2:46   1:59   min/km
Peak 60min (266 watts):
          Duration:      1:00:02
          Work:           958 kJ
          TSS:            75.9 (intensity factor 0.871)
          Norm Power:          296
          VI:               1.11
          Distance:      37.919 km
                             Min     Max    Avg
          Power:         0        612    266    watts
          Heart rate:    129    171    158    bpm
          Cadence:     30      136    73      rpm
          Speed:         0        65.2   37.9   kph
          Pace             0:55   0:00   1:35   min/km
My stats, first race with powertap
Entire workout (251 watts):
 Duration:   2:39:23 (2:39:39)
 Work:       2393 kJ
 TSS:        241.9 (intensity factor 0.955)
 Norm Power: 287
 VI:         1.14
 Distance:   97.428 km
  Min Max Avg
 Power:        0 1048 251  watts
 Speed:        0 74.4 36.7  kph
 Pace          0:48 0:00 1:38  min/km
 Hub Torque:   0 36.3 9.7  lb-in
RABUBI - how accurate is your FTP?
Spidy, we were loafing - D2D my Normalised Power was 319watts, this race only 293watts - much harder race.
My FTP is 300 Watts, based on my IDT sessions.
Only tested once on the road, 20 minte TT, came out at 332 watts x .0.95 = 314. But that was at a cadence of about 84, and I normaly ride a cadence of about 95. So I am working on 300watts at the moment.
1:38 per kilo.  Slowest of the year.
Rabubi....wat het julle gemaak?  Koffie?  Vakansie? http://s3.amazonaws.com/advrider/jkam.gif.  Kinders? http://www.advrider.com/forums/images/smilies/lieb62.gif  Of het julle die rumours gehoor van die flashing BMW en toe opgesit en gewag??  NSI van 7.69.http://s3.amazonaws.com/advrider/nono.gif
Mens kan julle ook nie vir een naweek alleen los nie!!!!  http://www.advrider.com/forums/images/smilies/fitz.gif
My FTP is 300 Watts' date=' based on my IDT sessions.
Forget the cadence, it's got nothing to do with your ftp.  IDT will always be a bit lower.  314watts looks about right.  Very difficult to do a 2h40 ride at an IF of 0.96.
So I should change back to 314 and recalculate the zones. If you re-calculate, there are 3 options, which is the one to work on, I use Coggan power levels. I am a bit new to this, please help!!
So I should change back to 314 and recalculate the zones. If you re-calculate' date=' there are 3 options, which is the one to work on, I use Coggan power levels. I am a bit new to this, please help!![/quote']
Did you create zones on the date you did your outdoor TT.  If so, delete the current zones that you have (based on IDT), and enter 315 as the FTP on the date that you did your TT.
Then re-calculate the power levels based on Coggan.  This process is not the most intuitive - it took me a while to figure out how it works.
From now on, if you find that your FTP has changed, select new zones, enter the date that you want your new FTP to become active.  Then select re-calculate power levels.
Congrats Bruce and 101% on a great raceClap
101% I think we are going to rename you to Mr consistency!!You just don't seem to have a bad weekend.Dead
Thanks nochain!!!!!!
I'm very fortunate to be apart of a great team. Bruce must be the most improved vet for 2007 !! ClapClap
Marco is always strong!!! he has a very strong race mind !! I dont think I've ever seen him suffer!!!!LOL
But I must admit .....My "consistencey" was almost out the window at D2D on the Tarlton road when you and Spidey put us in the gutter!!!ClapClapClap.....R.E.S.P.E.C.T!!!!!!!!!
That was his bad weekend, lucky for me otherwise I would have had no chance Big%20smile
Bruce, I see that you had a max cadence of 188.
Is that an error, a glitch or can you indeed pedal as fast as something approaching a Ferrari F360 flat out in 5th ?
Bruce' date=' I see that you had a max cadence of 188.
Glitch, that is for sure!!
