When there is no more pad left is usually a good indication.
Mine is still perfect and got it in December last year. Proberbly got about another 1000km on them. Thank you Avid.
Don't buy resin pads' date=' they self destruct in rainy conditions. Sintered metal are the ones to go for.[/quote']
Mmm....now that you mention it I think I was running resin pads when they dissapeared on me in the wet Ermm
The sintered pads got small metal flakes , usually copper in them . This makes for a harder pad that can get very noisy . They are also suppose to build up a lot of heat quickly . The are much harder than the resin pads therefor lasts longer . I got my bike with resin pads and replace them a the first asap . like Titus say , they r kuk .
Heat buildup is only a problem if you plan on resting your leg on the rotor   (Don't do it).  Sintered pads last long and when you need to brake hard, the noise doesn't seem like such a big deal anymore.  On one of the SA websites I saw it mentioned that sintered pads were "overkill for SA conditions", but all it takes is one very rainy and/or muddy day and your pads are screwed.  I also assume he limited SA to Gauteng rather than somewhat wetter and muddier coastal towns and cities.
