Nope, my son inherits it.
and.... the components are really naff. Faded handlebar anodizing (black bars are now changing into a terrible bronze purple-ish mess. ) The bars are also very narrow, a la old school XC. Stem is too long, becuase the frame is to small...
Seatpost wrong size., the list goes on...
I have a 27. spez seatpost alu. What size do you need
  • Replies 2k
A little progression over the weekend... Grips are just temporary, will get black ESI Chunky's. Would have loved 'clear' grips (anybody know whether one can get some) as that bar is just too 'sexy' to hide behind grips :w00t:
Note, wheel not completely slotted.
Pretty sure I saw some Clear Ryder lock-on grips the other day.
Thanks will keep an eye out. Maybe some nice black bar-ends to round it off then with the clear grips :whistling:
I had some and they lasted about 2 months. The rubber is nice and soft but wears out quickly.
Thanks will steer clear then, black ESI's it is. With some red bar ends then. Yes, on a riser. :whistling:
The on-one takes a 27mm seatpost.
Lemme know what you want for it?
Will look for it today. If it will fit then you can have it for 6 beers. Will let you know tomorrow
It actually takes a 27,2mm post.
It takes a 27,2mm post. Let me know if you don't come right. I also have one going for a 6-pack
Thanx, my tape measure does not do tenths of millimeters...
Grappie.....
You guys rock, if i dont come right with flat29's post i will give you a shout nick!
Found it. Just let me know when I must drop it for you and if you want it. In the week or can pop around the weekend. PM me
I need lots Nick.
Fork
Seatpost
BB
Crank
Handlebars
Stem
Tyres (have a set of wheels)
Front Chainring (34 probably, I have an 18 and 17 WB sprocket from Rapide)
Rotors (have a set of avid )
Like I said, this supposed to be a longterm project, Delta just kinda threw a spanner in the works in terms of timing
COME hubbers. Any body with some spares to help out
I also have 1 off maxxis crossmark but it is not tubeless
Edited by flat29
I have a stem and handle bar - Easton EA (its a matt silverish colour) 31.8 mm * 685mm with 9 deg sweep, the stem matches the handlebar and both are brand new as they were swapped out by the distributor when I purchased the bike last year. I don't have the stem length, sitting in Dubai at the moment but can check on Thursday morning.
Also have a white Rockshox Tora, straight steerer and QR
I can also try and get brand new alu handlebars, stems and posts if you want (really ridiculous prices if there is still stock) in white
Edited by Raab
