I am looking at upgrading only the frame of my MTB, what are the Key Factors to look at when I want to transfer my componants and FORK from old bike (frame) to new frame?
Looking at getting a carbon HT frame or Duel sus.
PLSE HELP!!!! :thumbup:
Check that your new frame has a tapered or straight headset...so your fork will fit. Check your frame size by measuring, cause frames differ from make to make. Check brake calliper compatability wrt mountings on the frame/fork. Check mountings for cable lugs on the frame. Check BB size. Check seatpost diameter. And then double check everything again.
type of headtube - normal or tapered although there are adapters
Headtube length, otherwise steerer on fork may be too short.
Headset type
Seatpost size
Front derailer type ie. normal or bolt on as well as bottom/top cable pull and clamp size
Bottom bracket type and size - you may need spacers or adapter if you have an external bb and the frame is BB30 for example.
Rear brake mount, may need an adapter
Seatclamp type
Goode deal here - https://www.bikehub.co.za/classifieds/3908-brand-new-2009-gt-zaskar-carbon-team-frame/
Im sure some shameless self promotion is ok after I gave some input :P
Thanks for these pointers, will check out componants etc on my bike and compare with availble frames.
Saw your Post, really nice frame. in CPT though :thumbdown: and would like to c before any purchase...
  On 5/17/2011 at 3:28 PM, Devm10 said:
...what are the Key Factors to look at when I want to transfer my componants ....
Spelling, definitely look at spelling as a key factor.
Otherwise you might end up with Spam components, a Fos Fork or a Crackondale frame.
These Chinese guys are quite good with this sort of thing!
Get the manufacturer's torque specs. And a torque wench (yes, I know, a girl in the workshop).
Either that or tighten till you crack something, and then back off half a turn.
@Tankman...that was a good laugh !
Hope the bike build is a DIY..taking it to the LBS may be faster, but def. decreases the fun factor.
I am hopefully going to be doing a bike build myself soon, so please post progress and pics...and challenges/solutions lol
Biggest factor to check is to check if the your fork and frame are compatible according to the manufacturers specification. If not you may end up with handling problems at high speed.
Rule of thumb, your hub to hub center distance should not change.
Dude, unless he's into downhill, no hubbers are in danger of that.
We do go fater than you thing but I have never given angles and all that other white coat **** any thought when I put a 160mm fork on my Morewood or a 120mm on my RDS . I have build a few bikes by using the spares from a old bike and if it does not fit you either force it or get a conversion kit . As far as derailures goes , it does not matter what you currently got on your bike it will still pull either top/sideways or bottom on the new frame . But if you get it right the first time you will save a lot of time and money . The only thing I have found to be a problem have been the fork , and then it would be the lenght of the shaft that goes into your the bike headset .
Edited by dirt-rider
  On 5/22/2011 at 3:38 PM, dirt-rider said:
We do go fater than you thing but I have never given angles and all that other white coat **** any thought when I put a 160mm fork on my Morewood or a 120mm on my RDS . I have build a few bikes by using the spares from a old bike and if it does not fit you either force it or get a conversion kit . As far as derailures goes , it does not matter what you currently got on your bike it will still pull either top/sideways or bottom on the new frame . But if you get it right the first time you will save a lot of time and money . The only thing I have found to be a problem have been the fork , and then it would be the lenght of the shaft that goes into your head .
Are you sure you're talking about the same thing here?
