Hi guys, Any recommendations on a bike stand to work on my bike? Find it ridiculous just to send my bike to LBS to fix jumping rear de-railer
This one is great. Allows major work like installing cranks easy, raises the bike so you aren't crouching and folds up easily. Pretty cheap off CRC as well. Model name is "Cycle-motion".
http://tacx2009.ilink2.nl/MEDIA-REPOSITORY/Afbeeldingen/producten/Fietsgereedschappen/Montagestandaards/Cyclemotion%20stand/T3075_CycleMotion_338x450.jpg
I use a Park Tools PCS9 stand. Bought it online from CRC two years ago and have no "real" complaints so far.
I got the PCS10. Slightly more expensive but they both work well.
The top stand will only work with bikes that have QR skewers on the fork - so no thru axles.
Use the same stand and am happy with it. Don't like stands that clamp the frame or seatpost
Give me your requirements and or a picture of the stand and I will custom build it for you, We are currently making normal rear triangle stands and wall hooks.
Can copy one in the photograph at what can be half the cost
Edited by BLACKvoodoo
How many moola you charge for it? :D
ok so i know i am not a professional mechanic but i use 2 holdfast straps that i run through the frame, 1 at the seat post join and 1 either behind the fork or in the weld where the top tube meets the downtube, and fling over 2 roof beams about 4 foot apart, means bike is in the air, sturdy as hell and i cant knock it over if i happen to wander 2 close etc. i know its not an answer to your question but as a cheap as chips solution to a problem you cant( in my opinion) get better. oh the straps are the std 25mm cam straps in case you are wondering, you may even have and not need to buy, worst case if you do need to they are only 50 odd bucks.
can be used from any number of objects, lapa timber poles, roof struts, trees, garage door rails etc etc.
Just make your own , its way cheaper than buying one , these are my two i made.
Nice and neat garage! A place for everything and everything in it's place! :thumbup:
:thumbup:
you can carry it anywhere in your pocket aswell !
Pretty much the same solution. My flat isn't big enough for most things. I've a chain that I loop over my pull-up bar and under the front of the saddle. Not ideal - it's a squeeze in the doorway - but enough to work on most stuff like re-indexing.
