I have read a lot about what lube to use on my mtb chain. In the past I have used Epic White Lightning dry lube. However on my first wet ride that caused a lot of issues. So I went over to Motorex Wet Lube, the one endorssed for the Cape Epic. However on a ride like the recent Nissan Trailseeker #4 at Van Gaalens I used it. Had a lot of dust and sand stick to my chain causing some chain suck.
What is been used out there for wet races/ dry races?
  • Replies 36
Used that stuff too, been using the Boeshield stuff which works awesome, as well as the Blue Rock'n'roll stuff.
Solomons sells both for just over a 100 bucks.
Chain-L is great too but I find that too much crap sticks to the chain when I use that.
i have used finish line (green) for as long as i can remember and have been very happy with it. Have always had this nagging sensation in the back of my head about using squirt so i tried squirt for sani cos we were given a bottle and it was being squirted at every stop.....had endless shifting issues...not sure if it was related...but i am back on the good stuff now
A note from JB's excellent pdf on chains
"The science of lubrication, friction and wear is called tribology and is a branch of engineering.
Tribology is a very well-understood science and tribologists are employed by lubricant
companies, bearing manufacturers, vehicle brake manufacturers and just about anywhere you
can expect to solve a problem of friction and wear. Tribologists know that the best lubricant for
bicycle chains is a long-chain hydrocarbon, commonly known as oil. Not wax, not graphite, not
liquid Teflon (which doesn’t exist) and not virgin olive oil, just plain old mineral oil. Often, you’ll
see a new chain lubricant on the market that promises to not suffer the same side effects as oil.
Stay away! If the manufacturer uses words like “dry”, “wax”, and/or ”clean”, it is probably rubbish.
It doesn’t matter that the product’s marketers claim that it was developed by a tri-athlete who won
the Australian open three times in a row back in the 1970s when men were still men and bikes
made of iron. The “developer’s” day-job is most likely that of third oboe player in the local
orchestra or speculating with pork-belly futures. He knows nothing about tribology.
Those popular dry wax lubricants are a combination of a volatile solvent or carrier fluid and a
waxy substance. Once squirted onto the chain, the solvent evaporates, leaving a waxy coating.
At first, the chain is quiet and lubricated and like the bottle says, there is no black mess. However,
this is no free lunch and very quickly – even after just two or three hours of riding – the waxy
substance is worked out of the joints and being a solid, it cannot flow back into the interface. The
result is a dry, noisy chain. Perhaps that’s why they call it “dry lubrication”.
Liquid oil on the other hand, gets pushed out with each cycle but also flows back as soon as
pressure is taken off the chain i.e. it flows back into the pin/sideplate interface during the link’s
journey from where it exits the chainring and enters a rear sprocket.
Testing the difference between wax and oil is easy: squirt some of the “dry liquid wax” onto a
smooth surface and wait until it is dry. Rub it with your fingers and note its texture, slightly rubbery
and certainly not slick. Notice that when you scratch a line through the blob, it does not flow back
to fill the void. Now put a drop of oil on the surface and do the same. Play around with the two
substances and you’ll notice that oil flows, wax doesn’t. You’ll notice that oil can be washed off
with soapy water and just about any petroleum solvent. Wax has to be scraped off.
Now imagine the “wax” on your chain. It coats well, but doesn’t lubricate once it has seen enough
work to push it out of the important chain wear interfaces. Washing it off is another matter. After
one or two applications you’ll have so much build-up on the jockey wheels and all parts of the
chain - where ironically lubrication is not needed - that you’ll be searching for something to
dissolve the mess.
I’m sure you’ve often heard someone say that oil “attracts” dirt. This is nonsense. Oil has no
magnetic properties. It merely traps whatever lands on it. Yes it is a problem but far less so than a
chain that’s effectively dry after just a short ride. The dirt collecting on the outside of the chain
doesn’t matter; it’s the oil that’s still on the inside that is doing the work.
Silicone spray lubricants may silence noisy door hinges but they’re useless for bike chains. Again,
this is a two-part liquid – a volatile carrier and light oil. The liquid is sprayed onto the surface and
quickly penetrates deep into the chain. The volatile liquid then evaporates and leaves the surface
nicely oiled. However, the oil in silicone sprays is simply too thin for use on a chain and offers
little more lubrication than water, and is about as long-lasting as the latter. A chain lubricated with
silicone spray makes a sound typical of a dry chain. Try it once and memorise the sound the
chain makes after twenty or thirty kilometres. Memorise it and save your chain from wear
whenever you hear it again.
Something that looks similar but isn’t, is motorcycle chain lubricant. This is also a spray and
therefore appears similar to silicone sprays. It also has a two-part composition – solvent and
lubricant. The latter comprises thick oil in a volatile carrier and does a good job of penetrating the
chain and keeping it oiled in prolonged riding.
The drawback of spray lubricants is the mess. If you don’t develop a technique of catching the
overspray with a cloth, you’ll end up with grease marks on your garage floor. Overspray also has
the habit of getting onto the rear rim, where it at first makes it impossible to brake but later starts
to dissolve the brake pad rubber and creating a gooey mess on the rim that makes the brakes
grabby and noisy.
So how do you choose a good lubricant? Go to your bike shop and find a product that openly
professes to be oil. Anything with the word “dry” or “wax” should be ignored. Find an oil that’s
viscous enough (not too thin) to not fly off the chain when you start spinning fast but that’s also
not too gooey to develop long toffee-trails where the chain exits from the sprockets. Brand names
are not important here because I’m talking good old mineral oil pumped from the guts of the earth
and sold by the barrel on the commodity markets.
Bicycle oil is expensive by petroleum product standards and those little bottles are ridiculously
overpriced. If you don’t want to pay the equivalent of one million dollars a barrel, use plain old
engine oil. It works well, but I don’t like the fact that engine oil is just a teensy bit too thin and
throws tiny little drops of black onto my shiny silver rims. If you don’t want to start your own oil
refinery in the garage, I recommend one of the more tenacious bicycle oils typically sold as MTB
oil. I have experimented with chainsaw oil, sometimes called bar oil, on my chain. This oil is very
thick and designed not to fly off fast-moving chainsaw chains. However, it is a bit too sticky and
soils your back wheel by throwing off spider web-thin trails as the wheel turns. I have
experimented with a mix of engine oil and bar oil and came up with the perfect viscosity that
neither throws off drops nor pulls trails. This mix, which ended up as a 2-litre batch, will now last
me for the rest of my life. I dispense it sparingly onto my chain by using a commercial bike oil
dropper bottle.
New products on the market claim to outlast other oils by huge distances. Their claim is true. With
the addition of tackifiers, they managed to make the oil very tenacious and it stays on the chain
far longer than other oils on the market. Although this sounds good, it has a downside as well.
Riding that long with contaminated oil isn’t a good idea. It would be better to simply clean and
relube each day, rather than relying on something that may last you an entire MTB stage race.
When touring, I seldom take oil with me. The bottle always leaks and causes a mess in my saddle
bag. Instead, I make use of the free lubrication service offered at every garage in the country. Pull
in at a convenience garage, head for the black plastic rubbish bin and scratch around until you
find an “empty” oil can. Inside you’ll find at least 25 ml of oil, enough to lubricate the entire Tour
de Farce squad’s bikes. Now courtesy of your average smoker, find a used match. Tilt and
maneuver the can until you get some oil on top, dip the match and dispense the oil, one drop on
every second link, and ride into the sunset.
Prolonged wet riding effectively cleans all oil from bike chains. This isn’t a problem as long as it
keeps on raining. Water is also a lubricant and a wet, oil-free chain is still a happy chain.
However, when it starts to dry out, the chain will start squeaking. Pull up at your first friendly
Caltex and make use of the free bike lube service."
I will try those you have suggested.
Any of those good for wet and dry or is the consensus wet 1 type of lube and dry another?
How about longivety? On a 70 km ride would I need to relube?
JB, you have saved me a load of cash. From now on I will use normal car oil. I presume the thicker car oil will be better so I will ask the petrol attendants which ones are thicker.
I think the older the car the thicker the oil?
PS: Thanks Stretch for finding that article.
dissolve the mess.
grabby and noisy.
dropper bottle.
I was thinking of using chain saw oil but that is answered in your reply.
This is obviously not applicable to SA ito the lube service at filling stations. I would not want any attendant going near my bike. Have you seen those township bikes?
