Hi guys
Well it started with the bearings on my front hub being stuffed. The price you pay when you weigh 100kgs and jump you bike with a rigid fork off every obsticle you can find. Yes like a small child.
(There was alot of lateral play in the wheel and the bearing were being to squeak and there was excess friction, :ph34r: especailly on the uphills.)
Anyway got quotes from two LBS (wont name them cause they are both actually great shops I get great service from them and the quotes are actually fair enough when you consider what genuine parts cost and their labour)
The quotes I got were:
LBS 1: R 380
LBS 2: R 400ish
Didnt wanna spend that much money on something I was sure I could do myself.
The bearings looked pretty standard so off to BMG.
So R70-00 and 20 mins later.
post-16067-0-51738300-1370006589_thumb.jpgpost-16067-0-46393000-1370006625_thumb.jpgpost-16067-0-35989700-1370006643_thumb.jpgpost-16067-0-43800000-1370006664_thumb.jpg
Now before I get scolded, I know that any warrenty is now void, and I have hugely devalued the wheels.I know that these bearings are probably not as good as the original DT Swiss one. But I have been through two rims on these wheels and they are already as far from original as possible.
I would love to have used my LBS but just didnt hav ethe extra cash at the time and thought what the hell let me try.
Ok bring on the uitkak :nuke:
  • Replies 35
Very interesting reading.... :thumbup:
I was having the same problem last week. After the Sani i decided to strip both my bikes and clean them properly. Last week Friday afternoon i decided to assemble one for a ride on the Saturday morning. Big was my disappointment when i find that the front wheel bearing is is not turning. :eek: Since the Giant Trans was not going to be ride able, I decided to assemble the Giant Anthem for the ride. That also did not work as the back wheel bearing was making a noise.
Long story short i decided to strip both bikes hubs and was pleasantly surprised how easy it is to service the DT Swis hubs. Without having bearings (Friday afternoon) i open the side of the sealed bearing and washed them out properly with solvent, re-crease and fit them again. Work like a charm, but will get bearings from bearing man and replace them rather.
I will rather service my own hubs in the future.... :whistling:
nice stuff. it crazy how easy it was actually.
Lekker! Hope Pro 2 Evo hubs are just as easy to do. Cost me R200 for rearhub(4x bearings) and BB to replace.
so Hopes are DIYable. Any special tool needed?
I was under the impression that the Pro 2 Evo's used proprietary bearings, while the Pro 2's used commercial over the counter bearings...
Got the Evo's and enduro's work perfectly.
You missed a bearing - there are 5 in that hub and freehub.... 1 of which is a non standard size.
Special tools are not really needed - but they do make it easier - and do less damage to bearings when removing them - especially if just stripping to clean and regrease.
I have a set of hope hub and bb tools - well worth having - but if someone needs help stripping a hope hub, pm me - happy to help or loan tools to use (but only in my own garage)
I am doing this overhaul on Mavic Cross Ride since 2009. No problem. Bearings are standard. 3 x bigger ones, and one smaller one at the free wheel hub. Forgot the exact dimensions, you can get it on Mavic's web site.
Watch out for excessive hammering. I use a piece of threaded rod as a bearing puller. This will pull the bearing parallel to the axial line. Also, hammering is avoided when when you pull in a new bearing on its outer racing [ring]. You will find that one of the sockets in a socket set has an outside diameter [OD] a little smaller than the bearing's OD.
If you find a job simple, then it is not neccessary to run to your LBS - do you take your bike to the LBS to pump the tyres?
I seem to be unable to get my freewheel body of my hope pro2s.. Anyone with advise as to how I can remove them?
WD40, but know that you will have to clean and regrease after. Spray WD40 on body and hub. let it soak in...wait for 5 min or so. And then just pull the freewheel body off
