  • Replies 38
I recall a year or two back that they pulled out of the specialist independent stores and were only supplying one of the chain stores. Cant remember who? May Sportmans or Mr Price
Decided back then that I wont buy k swiss again!
What other shoes also have holes in them. My main issue is when the water from the spunges fills my shoes at IM. K-Swiss has holes so the water can drain.
Zoot?
Zoots I think...no idea where you can get them in SA tho....if at all
Ah see DaveM mentioned them, sorri...
You could always modify your existing shoes with a few well placed small holes, it worked for Bruce Fordyce a few times when he won comrades...
Edited by SwissVan
http://www.chainreac.../en/s?q=k swiss
Chain reaction has 15 pairs but they are ALL womans shoes.
What is the major difference between woman's and men's shoes? Obviously woman's shoes have shorter toes so that they can fit in easier behind the stove and washing machines but what else?
They have higher heels
No joke, modify your current shoes and make a utube video for the hub...kind of like the toobless conversions except you can call them waterless...
Seriously now... I remember BF cutting of part his running shoes in the toe box area to let his big toe (and blood) to come out
Garfield will look Pretty in Pink!
They may even let you start in the last wave.
Edited by davem
Also try Amazon, my wiff just bought a pair of running shoes (older model not available in most shops) from Amazon, the second pair she got there
Ladies have a narrower and shallower heel generally, and shoes will be narrower (B width vs. D for men)
I believe the Asics Noosa tri range may have drainage holes as well, so have a look.
Cutting out the front part of your shoes or even taking shoes along that are about 2 sizes larger than your normal size is pretty standard for trail ultras to remedy foot swelling or blisters. Crazy bunch :whistling:
