Hi, thinking of replacing the press fit BB and maybe some of the pivot bearings (Giant). What kind of tools (press/puller) do I need.
I know my Trance has a couple notches behind the bearings, if you careful insert a screwdriver and SLOWLY tape the bearings out.
I used a couple nuts and washers to press new ones back in.
Be patient and ensure they go in straight.
Edited by Alouette3
to install bearing just take a piece of threaded rod with nuts on each end, use the bushings provided and bob is your uncle.
I found using varying sizes of sockets worked well with a long bolt and washers to get the pivot bearings in and out...
Edited by Stoffel76
