Funny enough I had a new entry level bike with Tekro brakes and they stopped dead without a sqeek.after that got a second hand bike with XT brakes and they screamed like pigs,sorted that out with a new pads,no problems whatsoever anymore.
Few things which will fix the pig:
True rotors
Deglaze rotors and pads
Clean with isopropyl alcohol
Ensure calipers fitted to "clean" frame (no paint in between)
Apply thin (very thin) layer of copper grease between pad and plunger
Do the bedding (run-in) procedure
If still screaming, strip service calipers and bleed system
Edited by veonix
  On 7/9/2014 at 6:04 PM, River Rat said:
Take off the wheel, take out the pads. Get a can of Q20 with a long thin nozzle. Spray oil into the opening around the brake pistons. That will allow the pistons to retract and release contact with the brake pads.
You may want to think about this a bit. Q20 will make the seals swell and become gooey and lead to sticky pistons. The Q20 trick will work for a short while and then disaster, if enough gets in there. Problem is, Q20 is not pure silicone but a compound that also contains chlorine. A chlorine-free lubricant like Q8 (IIRC this is chrorine-free) made by the same company, will work. However, the recommended method is to use the same fluid as the rest of the system i.e. mineral oil or brake fluid. As an aside, I was taught how this seal-swelling trick can help you if you're in a fix. By applying a little bit of Q20 to a wrist-watch gasket when you've changed the battery and don't have a new gasket, it swells and goes soft, and then seals again.
And that's how we learn, thanks.
  • 10 years later...
  On 7/9/2014 at 4:38 PM, Cyclo said:
Hey guys, I bought not long ago an off-road bike (Titan) and from day one I got my noisy disk brakes ( Tektro ) I sent it 3 times to the shop and every time they were saying that "nothing wrong with the bike...now is fixed" and after the first km. of riding starts again. It is not the cheapest bike though. Ten grand I think is a good amount of money for which you have to get a proper machine. Now, I can't spend more time and petrol to deal with "mechanics", so I am trying to get an advise from someone from the forum before I go and spend money on new brake pads without knowing what actually would've worked best. I will appreciate your help.
Thanks.
Expand
damn, 10 years later and I too have this issue with my brand new titan ('24 rogue dash) bike Tektro rear brakes.
Expand
Bed them in by pedaling while holding the brakes until you come to a stop. Release and repeat a few times until the brakes are sharp. Then use some rubbing alcohol to clean the rotors of contaminants. If they're still noisy then remove the pads and give them a light sanding on a flat surface to just scuff the surface and remove any grime. Be careful never to touch the rotors or discs with your bare fingers even if you've washed your hands. Your natural oils are enough to cause contamination.
