R120.00 6watt LED lights : DIY
wazi
So I needed some strong lights for the MRS and I.  At over R700ea it was not an option to buy two sets.  So I went about making my own set for about R120ea.
I will be posting a "set by step" as I have time just in case anyone wants to make their own.
All electronics were purchased from http://www.rabtron.co.za and I highly recommend them for their helpfulness and quick service.  If I had any "electronic" questions they were happy to answer.
Here's the parts list:
6 x  3W High Power Led - White - 160~180lM
R114.02
4 x  B165L Push Button Latching Round Red
R31.46
3 x
High Power LED Lens 45 deg
R34.20 1 x  Heat Shrink Tubing 12MM BLACK - Per Metre
R12.00
1 x  Heat Shrink Tubing 3.5mm RED - Per Metre
R5.00
1 x  Heat Shrink Tubing 3.5mm BLUE - Per Metre
R5.00
2 x  B163B Mini Push Button N/C Black
R11.99
1 x  Heat Shrink Tubing 1MM BLACK - Per Metre
R3.00
1 x  Heat Shrink Tubing 10MM BLACK - Per Metre
R10.00
1 x  Heat Shrink Tubing 1.5MM BLACK - Per Metre
R3.50
3 x  Battery Clip For 9V PP3 Battery
R8.58
2 x  Battery Holder 4xAA Long
R15.73
3 x  High Power LED Lens 25 deg
R34.20
6 x  3.9 OHM 5.0W 5% W/W
R19.84
BUILD PART1 (click to follow)
You'll notice I bought extra LEDs and extra resistors just in case :)
The heat shrink tubing is just a nice to have and not expensive.
Here's the finished results:
theMK1
theMK2
Stay tuned for the "step by step" build which I should be up here by the end of the week :holding thumbs:
BUILD PART1 (click to continue)
  On 3/4/2015 at 3:33 AM, madbradd said:
Good luck with build. Out of interest why no constant current driver for the LEDs?
l
Would it not be Constant Voltage instead of Constant Current...?
MadBradd:
Cause I'd either need one for each LED or a powerful one to drive them both. Would've added R400 to the build budget and I wanted to keep costs down.
  On 3/4/2015 at 3:54 AM, JXV said:
No batteries listed in your parts. Using normal AA cells? How many in what configuration?
good question as there was a Lot of decision making involved in choosing power. Will give more detail later but basically I have a lot of rechargeable AA batteries so I'm using them in a 6v configuration. Using the "Battery Holder 4xAA Long" to package them.
Thanks Wazi for you're time to put it down on paper for us, keep us posted and I would like to see how strong the beam is at night time.
Yes "the nerd" we need more threads like this!!
  On 3/4/2015 at 6:32 AM, dirtypot said:
Awesome!
Post some pics at night showing how they illuminate - like the Extreme Lights ones.
I love the home hacks  :clap:
Thanks...
The beam itself is decent.  Will get some pics compared to an off the shelf model.
  On 3/4/2015 at 7:36 AM, the nerd said:
i just want something like this for helmet... I dont like these big ones for my helmet
If the beam shot is good, I'd like to do this for the helmet too.
