Tool purchase advice
cadenceblur
Hi guys
Need some advice...
I'm looking to do more of my own bike servicing and therefore need to build up my tool kit. I'm looking at getting quality tools, so probably Park tool?
I currently have the following :
Chain Whip
Chain Breaker
Cassette removal tool
Allen key set (Park Tool)
External BB removal tool
Pedal spanner
Cable cutters
So, I am able to remove and reinstall a crank and cassette, looking at doing more stuff like servicing my own hubs etc.
Road and MTB
Where do I start?
PS I have a Tork bike stand, which is pretty crappy so looking at an alternative there as well..
  • Replies 33
Guest notmyname
Cone spanners. I tried and failed to service my hubs last night due to the lack of these little nasties.
Edit: bleed kit. Quick link removal tool thingi.
Okay, cone spanners. Are there standard sizes?. I hear you on the bleed kit.
http://www.cwcycles.co.za/product/birzman-hub-tool-9pcs
depending on what your requirements are you can get them loose, but a set it better if you get a different bike/wheelset later
I'm using quick links at present without any removal issues. What does the tool do?
helps removing the quick link as they are not always easy to remove
The newer (black) 10spd SRAM quicklinks kinda clip together quite tight. near impossible to undo them by hand and difficult with needlenose pliers.
SRAM recommends breaking the chain not by removing the link but by pushing the pins out of a separate section of chain using a chainbreaker and then replacing with a new quicklink....yeah right...they just wanna sell more links.
The quicklink pliers work really well - get a pair that can both open and close the links. Some of the cheaper pliers can only open them......
