XT Brakes seizing up
Maniac Merv
So I’ve done a couple of enduro's where I’m hard on the brakes ect ect and never had a problem what so ever  , but last weekend  on Day 3 of Mankele 3 towers when it was F*$% hot , my front and rear brakes seized up so bad that you could not even spin the wheel for the last 5 km.
Got home and  washed the bike next day and took out pads and brakes to check out whats going on and they were  loose , then when transporting my bike to the shop for a check up,  they seized up again while on the  back of the bike rack
Is this a shimano fault or a heat problem or fluid expanding or pistons  ?
XT with ICE rotors
It could be an air bubble in the line close to the calliper. When the air gets hot it expands and pressurises the system pushing out the brake pads and seizing up. A bleed should solve it.
How old are your XT brakes.   The pistons get worn and don't slide as smoothly anymore and eventually seize in the levers...  I would imagine the things heating up might compound this seizing.
I had the same happen during Trans Baviaans to my front brake after extreme braking.  The piston in the lever seized and would not release the pads. The brakes are about 4 years old with heavy use.
This years 3 Towers also had some hard braking sections.
Bleed them
XT with ICE rotors
bleed is needed
  On 10/9/2015 at 9:25 AM, Baracuda said:
Mine were great at first as well. Now they make the dreaded throttled turkey noise with reduced breaking umphh
1. check for contamination and replace pads where necessary
2. skim rotors
3. follow correct "burning in" procedure
4. bleed
5. check caliper alignment
  On 10/9/2015 at 9:33 AM, fanievb said:
Bleed them
bleed is needed
2. skim rotors
4. bleed
This............. Best answer to date. I had similar issues and a clean and bleed sorted it out.
Just been through the exact same issue with some 785's, last night I started off washing them in a bucket with warm water and a brush to get them spotless, then did the "off bike" bleed, flushed out the system bottom up completely, lubed the outer part of the pistons with some excess oil, going to refit them and leave them the bike in the sun today and see if it worked.
Next step will be to flush them out with IsoP and refill with oil, failing that they are off to the agents for warranty.
Edit: Spelling
  On 10/9/2015 at 9:46 AM, madmarc said:
Replace with SRAM XO Tail brakes - Problem sorted  :ph34r:
http://cdn.24.co.za/files/Cms/General/d/2304/4aad279b1b63409bbc16b0723756abcc.jpg
So, after doing a full bleed bottom up with the brake off the bike and using the "funnel" method (and bleed block etc), I left my bike in the sun for 5-10 mins today as a test and the rear still does the same.
Is it advisable to to rinse / flush them out with Isopropyl, let them dry out and then refill with oil?
By 'seizing' I presume you mean pads gripping the disc when there is no pressure on the lever. A better term for this is 'pumping up'. 'Seizing' is when one or more pistons gets stuck in its caliper bore.
Routing to rear often has a high point in the brake line where air can collect..if this air gets warm it expands and pads may push out to the discs. Overfilling with oil can also cause this.
All your issues seem to be when the brakes get warm from sun or actual braking. So I think you might still have air. Take caliper off the bike and hang it vertically down while bleeding.
Good as they are, XT brakes can't be rebuilt so if they are old or abused, might be a faulty lever needing replacement.
When you bleed, do it properly with the bleed blocks in place to prevent over or underfilling and follow the Shimano service instruction exactly - not some diy home video off the web with steps missed out.
I've had several sets of XT brakes and used them hard - never had this problem. Hope you get it sorted....no pun intended.
