Snapped rear axle
dillon
So on my ride this morning, 2 spokes snapped (one the nipple broke in half), so I headed home with a wobbly wheel.  when I took the wheel off to fix the spokes i found my rear axle in 3 parts. I have not been jumping crazy jumps, apart from a few little drops and log jumps.
Hub has been trouble free for 2 years,  the break is on the drive side, not sure my power output is strong enough to snap an axle.
Any ideas why this would happen?
Hub has been trouble free for 2 years,  ---- Clearly not this here BikeHub?? :whistling:  :whistling:  :whistling:
Im curious to know why that would break in 2 places and not 1
all i can think of is the endcap loosened up a bit allowing the freebody some play, causing the one snap.
but to snap in between the 2 bearings (which are about 1000kms old, with no play), i am stumped.
About to write it of to my immensely powerful legs  :whistling:  :eek:
I'm betting that was caused by a jump landing or a hit on some obstacle in the trail? The shape of the axle shows a clear stress concentrator at the tapered bit. The main bearing on the drive side is far inboard to accomodate the freehub. This raises the stress on the axle in that area quite a bit more than the non drive side. The sharp taper on the inboard side of the bearing flange was not a good design choice.
The second break looks to have occurred under one of the freehub bearings, not sure how that happened.
I think I would replace with a more robust hub to avoid this in future.
The inner freehub bearing places a load on that point on the axle if one of the end caps comes loose and allows sideways play. It's a pretty common place for these axles to fail.
I always thought Novatech was one of the few Chinese products that is actually good. You have just proved me wrong.
nothing wrong with the hubs, my son runs them as well, and he rides them hard, racing in the A batch.
This is a perfect case of lazy maintenance. If i had put loctite on the end cap when replacing bearings, we would still be riding.
mmmm I haven't had any jumps or rocks for some time, i am starting to think the end cap came loose, which caused the break on the freebody and I broke it again when trying to remove it .
fact that I rode 25kms with it broken might also have something to do with it....
Maybe you should train less...or get a stronger hub [emoji12]
Can you post some photos of the fracture surfaces, end on or 3/4 on. It may be possible to see if ithere was a fatigue fracture or just an over stress. (A boffin with a microscope or a 10x inspection lense should be able to tell you something.)
Also what is the material. Steel, stainless steel or something else? It looks a bit bright for a high carbon steel bike axle.
I would guess the first break was due to an overstress, manufacturing defect or possibly missassembly. The others could be collateral damage from riding it home. The evidence of the first break might have been masked by other damage on the ride home. (But rather ride home if you can, then push 20km for the sake of science!).
