  • Replies 54
I had this issue with my Easton hub,
after 1 wet ride I had a crunching noise in my freehub, stripped, cleaned and regreased and put it back, only to find it clicked. turned out to be 2 of the 3 pawls in the freehub were shot and had to be replaced.
Check that they release smoothly when pushed in and use a light durable grease to keep them quiet.
If that doesnt work.....put new bearings in
Definitely not the QR skewer as the bike is now even more noisy.
Will try a new chain, as mine is old and needs replacing anyway.
If that does not help I will strip the hub again and lube everything up
C'mon guys, surely someone has had this issue before...
I've cracked a Tune freebody before
They are Superlight but under engineered..
If prince, core move axle, if you have the Carbon axle... Check for cracks
If cracked...
A new one is mucho ZAR...
Good luck!
If cracked...
Good luck!
I have got the aluminium axle. And it's in perfect condition, so it's not that
Take it to David, he is a superb wheel builder. He has probably seen this before and knows what and how to look for it.
You don't want to stuff those hubs up!
Thing is, I just want to confirm that it is the hub, before taking it in
