Tacx Trainer help
Pieterlab1
Guys I need some advice please.
I got an almost new Tacx Bushido trainer for a very good price. I checked the specs on the Tacx website, and they confirmed that a 29" wheel will fit.
I assembled the unit today but my MTB doesn't fit. On the unit they mention max outside wheel circumference is 710mm.
Do I need to get a Tacx trainer tyre? Will this solve my problem? There is a 29" Tacx tyre availble on the CWC website.
I really regret ever opening the "Show you winter pain cave" thread!
  On 5/17/2016 at 4:34 PM, Zatek said:
I would always recommend a infoor tire.
It will last longer, be more quite and less of a mess.
Thanks! So it should fit with the trainer/indoor tyre then?
I have vortex trainer. There are different slots that the brake can attach to the frame of the trainer for different wheel sizes. I suspect your trainer has been screwed into the wrong slot for 29er. Try download the manual off the web, you need to see the diagram, a worded explanation makes it more confusing than it is.
Thanks, I did slot it into the biggest slot, but it's still not accomodating the wheel. I guess I need the trainer tyre.
I've ordered the trainer tyre from CWC, it should be delivered later today.
I plan on fitting the tyre to my old 29" Giant tubeless rims. Do I need to fit it with a tube, and what size tube do I need?
This is your problem
Yup. Most trainers don't accommodate 29er wheels with tyres >1.4"
Buy a cheap 29er mtb or 700c road wheel and add the trainer tyre and cassette - swap wheel when you want to ride indoors - much easier than changing tyres all the time (especially if it's tubeless).
Much too lazy to change tyres every time! I will fit the trainer tyre to an old wheel, thanks.
It is screwed into the biggest slot, but still the 29" Maxxis MTB tyre don't fit. I hope that the trainer tyre will fit.
Tube size depends on tyre size
Edit: 29er and Road Wheels are the same size.
It's the only way.
Get an old cassette too and keep the wheel purely for the IDT.
  On 5/19/2016 at 10:18 AM, carbon29er said:
It's the only way.
i ended up with a whole new wheelset, so I've got that going for me which is nice.  :clap:
but seriously, get a whole new wheel, cassette included. It will be far less pain in the long run and you'll always have a wheel to train or ride on at a moment's notice. Don't go tubeless on the IDT wheel, just bung a tube in there
Thanks!
