News bot Posted July 13, 2016 Posted July 13, 2016 Engineers behind Quarq and RockShox will bring ShockWiz to life. Dusty Dynamics’ Nigel Wade continues to work full-time on the project.Click here to view the article
NotSoBigBen Posted July 15, 2016 Posted July 15, 2016 ok....so what does it actually do? https://www.google.co.za/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=what+does+shockwizz+do madbradd 1
V12man Posted July 15, 2016 Posted July 15, 2016 This has huge application amongst off road motorbike and car racers if properly developed, it's better than a shock dyno and replaces a bunch of expensive kit to see what your setup is doing (and therefore almost no one does)
madbradd Posted July 15, 2016 Posted July 15, 2016 I can't seem to find any info on whether it will assist with rear suspension as well, or if it is limited to the fork.
Wannabe Posted July 15, 2016 Posted July 15, 2016 (edited) I can't seem to find any info on whether it will assist with rear suspension as well, or if it is limited to the fork. The writeup said it does support both, and for best results, one needs to be attached to each suspension point. (therefore two is needed) edit: ShockWiz is equally at home on a hardtail or a dual suspension bike. For best results on a dual suspension bike, it is recommended that you use two ShockWiz devices to tune the fork and shock at the same time. Edited July 15, 2016 by Wannabe
V12man Posted July 15, 2016 Posted July 15, 2016 I can't seem to find any info on whether it will assist with rear suspension as well, or if it is limited to the fork.The work on both - 1 unit for each concurrently they reccomend.
madbradd Posted July 15, 2016 Posted July 15, 2016 The work on both - 1 unit for each concurrently they reccomend. too much time in front of the screen..... Hope I didn't miss things like that in my work stuff!
Wannabe Posted July 15, 2016 Posted July 15, 2016 The writeup said it does support both, and for best results, one needs to be attached to each suspension point. (therefore two is needed) edit: ShockWiz is equally at home on a hardtail or a dual suspension bike. For best results on a dual suspension bike, it is recommended that you use two ShockWiz devices to tune the fork and shock at the same time. The work on both - 1 unit for each concurrently they reccomend. too much time in front of the screen..... Hope I didn't miss things like that in my work stuff! Are my posts invisible, or what? V12man 1
cadenceblur Posted July 15, 2016 Posted July 15, 2016 Hopefully a few bike shops will buy a few and rent them out.
'Kaze Pete Posted July 16, 2016 Posted July 16, 2016 Are my posts invisible, or what? What posts? [emoji23][emoji23][emoji23] Wannabe 1
Register a new accountSign in
