SLX deraileur on 11spd
Mawbs
Are you going to buy an 11 speed shifter? Or do you just plan on using 10 of the 11 gears?
Sent from my E5823 using Tapatalk
yes 11spd shifter
You might be able to get it to work, but it's never going to run smooth like a 11 speed derailleur would. Deraulleur geometries are slightly different, so even though you'll have an 11 speed shifter pulling the cable, the derailleur won't be moving the exact right amount. Never mind the fact that 11 speed derailleurs were designed to go up to 42+ teeth and 10 speed only designed to go up to 36+. I think you could make it work but it will be finicky and not ideal.
If it works with a 10spd cassette with the limit screw it then I don't see an issue with an 11spd cassette.
http://faqload.com/faqs/bicycle-components/drivetrain/using-shimano-11-speed-shifters-with-10-speed-derailleurs-and-10-speed-cassettes
looks like you might need to add a spacer for an 11spd cassette.
http://faqload.com/faqs/bicycle-components/drivetrain/using-10-speed-rear-derailleur-with-11-speed-shifter-and-cassette
