Wheelset for Gravel Grinder
Zorro5614
Hi Guys
Bought a 2016 Giant TCX SLR 2 a few weeks back.  The bike comes with a pretty heavy wheelset a just over 2.1kg.  Looking for something closer to 1.6kg.  As you may know, road disc wheelsets are pretty hard to come by.
So my question is, can I use a MTB wheelset.  Looking to run between 35-45C tires.  Is there anything to look out for when buying a MTB wheelset for such a bike?  I suppose it should be a 29er wheelset.  The bike uses Shimano 105 5800 groupset.
Will any American Classic or Stans wheelset work?  Should I look at internal rim width?
Thanks in advance
A quality mtb wheelset will work just fine - although you don't want to go too wide.
Also check that the max tyre pressure the rim can take will be fine for your planned tire pressure
I purchased a Rapid 29 wheel from Wayne at Rapide and it is a fair price. Lighter than my MTB wheels and run gatorskins at 6bar plus on the road. No probs. Lekker wheels and the service is tops.
I have 19mm MTB rims with 1.8 knobblies but never go to this pressure. Be careful.......
I had the same question a while back. Hublabd recommended that I go with MTB wheels.
So I got a set of Roval Carbon Controls, put some Maxxis Rambler 40c on there, run them at the wheels max of 3 Bar.
Love them!
I got some Rapide TR29 wheels. Awesome wheelset, and they look good too.
Just note that it, and most MTB wheels, won't take an 11spd road cassette - need to machine it down 1.8mm (11spd mod).
Hi Guys
Thanks in advance
To answer your question, some of the American Classic wheelsets have internal widths that are simply too wide if you want a versatile wheelset; ideally you want to be able to slap on some 28mm/32mm/35mm slicks for if you feel like riding a long road etc. and at the same time switch to 35mm/45mm knobblies at will.
For the above reason, I wouldn't buy a wheel that is more than 25mm wide internally, and the Rapide's 21mm internal width is working out great for me. I use 32mm slicks, Specialized Roubaix Pro, for 95% of my mileage and 42mm knobblies for adventure time.
American Classic makes a Tubeless Ready disc specific road wheelset which are available locally for around R12k, someone tried to sell them to me in my LBS the other day but I don't remember the model name (lol no ways am I paying R12k for wheels!)
So it really depends on what you want at the end of the day.
Thanks for the replies guys
Seems like I need something with 19-22mm internal rim width, but can withstand up to 5-6bar of pressure if I choose to run narrower slicks
Correct. But maybe only 4-5bar if you run 28c.
Yup I'm running my 32mm slicks at 4-5bar (road condition/weather dependant). 5bar is actually quite harsh @ 32mm
We sold quite a few of the American Classic Victory 30 Tubeless Disc Wheelsets at R4495 a set lately for Gravel Grinder owners.
Hi Naas
I see the Victory 30 has 18.1mm internal rim width.  What is the widest tubeless tires I will be able to fit on these?
Hi Naas
I have 19mm internal width Hope Hoops and I have run 25mm GP4000s with tubes and 40mm tyres tubeless. No problem.
Hi Naas
According to Challenge you can run 28 to 50mm tyres on a 19mm rim. If you want to run tyres in that range I wouldn't go wider then 21 internal.
A 25mm internal rim is way too wide for a 28 tyre. You can mount it and inflate it but the danger is that it could roll off the rim under load. I know of two occasions where this has happened to riders.
