NukeproofPeanut Posted May 14, 2017 Posted May 14, 2017 So entirely my fault, I put the bleed block in half arsed since I couldn't slide it fully in from the bottom (adapter blocking it), I slotted it in from the top. Looked good and seemed like decent contact for the pistons; but alas whilst pumping the break the piston cracked leaking mineral oil everywhere! Seems you can't buy these separately? So who has a broken slx calliper I can use for parts [emoji2] or are there 3rd party pistons available? Sent from my Mi-4c using Tapatalk
Captain Fastbastard Mayhem Posted May 14, 2017 Posted May 14, 2017 Eina! New caliper for you... Unless someone has a spare piston for you.
BeegMig Posted May 14, 2017 Posted May 14, 2017 Keep an eye on the classifieds.Maybe even buy an upgrade
NukeproofPeanut Posted May 14, 2017 Author Posted May 14, 2017 I might will check, where you based.Thanks! Sandton/midrand normally. Hoping to find a replacement/fix but until then I've stolen the wife's front break.[emoji1] Sent from my Mi-4c using Tapatalk
Captain Fastbastard Mayhem Posted May 14, 2017 Posted May 14, 2017 I might will check, where you based.AWESOME.
NukeproofPeanut Posted May 14, 2017 Author Posted May 14, 2017 Keep an eye on the classifieds.Maybe even buy an upgradeYa if I don't come right, might just get a set of zee's Sent from my Mi-4c using Tapatalk
Matchstix Posted May 14, 2017 Posted May 14, 2017 think there is a set of hope tech 3 v2 for sale on the hub
supertorro Posted May 16, 2017 Posted May 16, 2017 I have a pair of magura mt4 brakes with stuffed levers. Could match the calipers to your set?
NukeproofPeanut Posted May 18, 2017 Author Posted May 18, 2017 Thanks, but just so stole the deore of the wife's bike. She hasn't ridden it in like a year Sent from my Mi-4c using Tapatalk
BaGearA Posted May 18, 2017 Posted May 18, 2017 Thanks, but just so stole the deore of the wife's bike. She hasn't ridden it in like a yearSent from my Mi-4c using TapatalkBoer maak 'n plan...
