DU bushing for R350???
Grantpayne
  On 4/12/2018 at 2:29 PM, Grantpayne said:
I have a Giant trance x2 201 that has some vertical play in the back... figured out it is the DU bushing... LBS wants R350 for a new bushing
for A set maybe but on their own , nara fook
Is this LBS in the CBD by any chance?
That's actually not a bad price for the IGUS set. Sadly enough.
Unfortunately unless you know a tame machinist those IGUS sets are about your only option...
so i booked the bike in for first thing this morning... took it in after confirming they had the right DU bushing for a 2010 trance x2. “nope we don’t have that old style will have to see if we can get something else to work” - what a waste of time! any ideas where i can buy the DU bushing from elsewhere and install myself?
go to stoke suspension. i struggled a bit without the press
Do you just need the eyelet replaced?
this thing:
If its the eyelet hardware for a fox rear shock, do yourself a favor and bring it in yourself, waited on omnico for 4 months before giving up.
I used these guys
https://www.worldwidecyclery.com/collections/rear-shock-parts/fox
R199.00 for aramex global shopper shipping and they were here in 10 days from the states.
Cost me R550 with shipping for both eyelets.
I'd only recommend this if you know what size mounting hardware you need.
I may be wrong but I highly doubt Fox or Rock Shox have their DU bushes manufactured to a unique size.
DU bushes are available from places like bearing man in a wide range of standard sizes for very little money. You can probably pick them up for less that R30 each from bearing man.
that’s what i figured? i’m going to let the shop
do it once at R500 including labor.. then i will take the old one to bearing places to try find an exact replacement.
  On 4/13/2018 at 9:23 AM, Grantpayne said:
yes that’s all i need...
Maybe. If the reducer is worn you'll need a whole new kit, in which case you're stuck with the IGUS set.
If you've caught it in time you can replace the DU bush for 60 bucks. I've got them coming out of my ears.
