SRAM X01 shifting issue
thebob
Hi all
So I’ve been struggling with some shifting issues on my BMC Trailfox TF02. Setup is as follows: e-thirteen 9-46 cassette, 30t chainring, new shifter cable, X01 11 speed chain and a new XX1 chain. I have confirmed that the hanger is straight and that the limit screws are correct and that the chain length is right. So the issue i have is that the shifting is perfect for 90% of my rides, but at some point the rear mech starts skipping like the cable tension is too tight making the chain want to jump up to the next sprocket. It can also be set off after a big bunny hop or taking a big drop off. Get the bike home, slack the cable off and it shifts ok on the stand, get it out on the street and have to add a couple turns of tension back to get it shifting up properly. So it seems like an intermittent issue that I cannot get my head around. Any suggestions as to what to try or look at would be most appreciated.
Check that there is enough slack in the cable housing when the suspension gets a compressed. When there is no weight on the bike it might look like there is enough slack, but once the suspension gets compressed the cable and housing can pull tight causing odd shifting and cable tension issues. Usually a problem when cables and housings get installed on full suspension bikes where the cable routing goes underneath the bb. Let all the air out from the shock, compress the bike untill it bottoms out and check that the housing is not pulled tight against the bb or somewhere else on the frame. I hope this makes sense.
Think you guys are on to something. Doesn’t look like there is much slack under the frame. Will dive into it tomorrow afternoon and see if that is the issue
Just to be safe you should check your chain growth with the chain on the 46t cog and the suspension compressed.  The easiest is to disconnect the shock to make it easier to move the rear triangle up and down.  If there is not enough slack in the chain you could stuff up your rear derailleur.
Yup, that was one of the first things I changed. Original chain was too tight, the new one is perfect.
For perfect shifting, I recommend Shimano
I am tempted. Never had a issue on my Deore equipped Trek :thumbup:
but did they have a proper 1 x?
Are you sure that the new chain is not slipping on a worn gear?  This will happen on the most worn gear only.
Chain and cassette are both brand new. Had the same issue with the stock 10-42 cassette and chain.
Try a Shimano chain. With the E-thirteen cassette i found the SRAM chain to wide and caused shifting/grinding issues.
I'll keep that in mind if it isn't the cable routing
+1 for some sort of lack of cable slack under suspension load, sounds like the cable is getting hung up somewhere. Also look at possibly damaged cable outer?
I ran SRAM chains on my 9-46 E13 with no issues, so would tend to discount that.
What RD are you running - long cage?
Success! Issue was caused by not enough cable slack under the BB. Loosened the cable holders, adjusted everything for a bit more slack with the bike bottomed out and everything is groovy. Did some big (for me) hops and everything is staying put and no funny business with the rear mech. So happy to get this right, been haunting me for some time now! Still want to get back on the Shimano train though ;)
