Garmin Edge 520 Bundle HRM capability
breaker
Hi,
Can one use the HRM from this bundle with lets say a fenix or 935?
Ie could you swim and run with it and will it give you the same metrics?
Link to comment
Share on other sites
I am not sure I understand your question. Do you want to use the HR transmitter with other Garmin devices or do you want to use other Garmin devices simultaneously while doing a workout?
Link to comment
Running: You’ll get the basic metrics, but won’t get vertical oscillation
Swimming: Ant+ can’t transmit throught water, so you’ll need the swim or tri HR strap
Cheapest option to get all the metrics (run and swim), will be to ge the tri strap
Link to comment
Kewl, that helps ito of not getting the bundle then. I would assume that the tri strap would simultaneously pair to both my fenix and the 520 at the same time, for eg on the bike leg of a tri?
Link to comment
...I would assume that the tri strap would simultaneously pair to both my fenix and the 520 at the same time, for eg on the bike leg of a tri?
Indeed
Link to comment
It does. I do this with the HRM-Tri strap on my FR935 and 820 during triathlons with no issue.
Link to comment
