Boost crank or not boost crank?
lechatnoir
There is a ~ 1.6mm difference in chain line. You should be able to run normal crankset, depending on the size chainring you want to use. The chainring may cause clearance issues at the chainstays, but usually is no issue.
Edit: There are some offset shainrings available that will negate the need for boost specific crank, and normalise chainline
You don't have to have a boost crank.  If you already have a normal crank then use that and you'll be fine.  I use a normal crank on my boost frame.  No issues.
  On 1/11/2019 at 9:43 AM, lechatnoir said:
I'm building up an XC-type bike and the frame has boost spacing. Does this mean I need a boost-type crank? And if so, what is that exactly?
Same as a normal crank, except with the chainline offset 3mm further to the outer edge of the bike. But as people have said above, you do not NEED the thing. Existing one will work.
  On 1/11/2019 at 9:48 AM, fanievb said:
so, it's a chainring-thing, not the crank itself? so a chainring with the required offset on a regular crank will be OK to get the chain line right?
many thanks
many thanks
yes only a chainring with the correct offset (i made a booboo in my other post)
many thanks
That's the way I understand it.
(unless the new BB is some strange width)
What crank and ring do you have now?
Scouring the classifieds as I type this... Picking up the frame tomorrow and will get an idea of what's what
OMG, dont go buy a new "Boost" crank.
You can use your old crank and merely change the chainring to one with a 3mm offset rather than the standard 6mm offset.
And save a lot too...
I've been running around with a normal crank in a boost frame for the last year and the cassette, chain and rear of the world has kept turning with out a worry. Haven't been throwing away cassettes or sobbing over the endless stream of chains I've had to buy.
I WAS a little clueless TBH, but nope... not buying a boost crank... more like buying A crank, as I have nothing at present. I see a crank in the ads, so now it's a boost chainring... or at least one with the appropriate offset
Agree. Unless one is running SS, the chainline changes every time one shifts gear; so chainline is almost never ‘optimal’.
BUT running the currecf chainline would minimise wear on the outermost cogs
