Gravel bike build from 2013 Momsen AL529 HT
Wettas
Decided to share my build project with the hub and ask for any advice/comments. I am building a gravel bike from an 2013 Momsen AL529. This is what I already have:
1. Momsen AL529 frame, still need a headset for the frame
2. Giant P-XCRT 29er wheelset with maxxis tyres
3. Sram GXP 2x10 crank.
4. Fabric scoop seat
On order:
4. BXT 29er carbon fork from Aliexpress
5. Seatpost, stem, handlebar
6. RD, cassette, chain (groupset)
Still need:
7. Headset ( 1 1/8 to 1.5" , 52mm/42mm)
8. Brakes( front and back)
I will update this when parts arrive and as build progresses.
  • Replies 49
Rather get a 27.5 carbon fork from Ali. Bike will be lower at the front. Still enough clearance in fork to run a 40mm wide tire. It will just looks more in proportion than a 29" fork.
It depends on the size tires you will be running. I will go for 45 - 50c or 1,9 - 2,1 inch. Something that will give you more volume so you can play around with tire pressure depending on the terrain you will be riding. IMO stay with the 29er fork.
post-54517-0-43344600-1547706264_thumb.jpegSnap! @Wettas my new build project, Momsen AL229 which I'd like to turn into a gravel bike. Have wheels - Stans ArchEx
Have groupset - 1 X 10 Shimano, would like to try a 36T chainring
Don't know yet how I'm going to choose brakes and shifter combo for drop bars.
Don't have a fork yet.
Leka build this!
I did mine with momsen stf29 steel frame.
11-42 cassette with 36t front, works perfectly but a 38t would also work
Its an absolute joy to ride on gravel roads with the carbon fork.
I run vittoria 29x2.25 tires for volume and more comfort.
weight is 11.3kg
I am considering drop bars but need to look at shifter/hyd brake options and costs.
for now I'm all good
attachicon.gifIMG-20190117-WA00021.jpegSnap! @Wettas my new build project, Momsen AL229 which I'd like to turn into a gravel bike. Have wheels - Stans ArchEx
haha nice , going to go 2x10 (Sram x7 FD, GXP Crank [39/29] with Shimano XT RD, Cassette[11,36])
Decided not to go drop bars, mech brakes and shifters makes the build pricey. Sticking to a flat bar, negative rise stem and ravx stubby bar ends. That will push weight forward and give you two holding positions.
I ordered this fork, its on a good special now BXT fork
PS. I am trying to keep cost down as much as possible
What groupset/brakes will you be running?
Any decent hydraulic brakes I can find for cheap. 160mm rear and 180mm front. Was looking at that Hayes radar on amazon.
So you're going with a flat bar I assume ...
Interesting, I was going to stick to 2.1 maxxis crossmark tyres and thus my thinking was that because its a XC frame with steep head angle that it would have the same look as the original bike. Would the rigid fork lift the front end up? This is a cool idea, as it wont really influence the bb height and it would make climbing better.
Leka build this!
weight is 11.3kg
That looks awesome, is it a BXT fork? I see the fork fits a 160mm rotor without any adapters
So more a 'rigid' mountain bike?
Yes, I will definitely try out drop bars in the future and do the full transformation. At the moment I am relying on parts from friends to complete the build and beggars cant be choosers.
Sounds good! Always lekker building something different [emoji41]
