Boost / Non boost
Super Sywurm
Hi
This might be a stupid question, but I can't find a definite answer on google or at my LBS.
My old bike is a non boost bike, my new bike is a boost bike.  I would like to transfer my old rims onto my new bike.
Now the question:  Will the old rims work with new boost hubs?  Does the rims stay the same or do you also get boost rims?
Regards,
Heinrich
A few options about depending on the hubs you have and if you have to relish or not. Hope make their own front and back that are super simple and no relish required. MRP make adaptors for a range of hubs as well (DT swiss, Hope and more most need a relish on the rear) then you get the more generic ones that you can get off ebay for a few dollars.
Personally these guys work really well and the guys running ti are pretty great.
https://www.cyclingstuff.co.za/shop/fouriers-boost-hub-adapter-rear-wheel-hub/
https://www.cyclingstuff.co.za/shop/boost-hub-adaptor-front-wheel-hub/
the OP wants to know if he can use the old rims onto new boost hubs assuming he wants to rebuild the wheel (new boost hubs with old rims)
For sure, I was just put it out there in case he wanted to keep the same set up as he's running now rather than cutting out the rims and lacing to new hubs. It's called helping out a bit. A lot of shops will tell you need to get boost hubs for your new frame / fork which will cost a fair bit just to keep your fav' rims.
Correction - with the Hope Boost adapter kit the rear wheel doesn't not need to be re-dished upper and lower limit screws also need to be re-set on the RD, but the front wheel will need to be re-dished.
Hi Heinrich.
You can indeed use the same rims with new hubs.
Just make sure the spoke count is the same when getting new hubs.
And check with LBS (or online spoke length calculator) if you will need new spokes to take note of additional cost of spokes which is often overlooked.
Enjoy the new bike!!
Cheers
Hi
Regards,
Heinrich
This is exactly what I suspected.
depending on hubs, you might even get spaces/endcaps that will allow you to use as-is. though not with the advantage of the stronger spoke angles boost gives you
Some hubs can be converted to BOOST spacing, some can't.
What hubs do you have?
I have a American Classic wheel set (non boost).  I want to remove the hubs and fit boost hubs.  The non boost hubs is also American Classic.
