Hi guys my momsen str has a stuck dropper post if have tried coke, some penetrating oil and some force but it doesn't want to move does anybody have advice?
Of you're willing to bin the dropper it should be pretty straightforward
Of not, you should get a heat gun and strap wrench and get creative
Saw another handy tip with a penetrating oil, remove the bb and drop a ton of oil in via the BB shell to penetrate the post from the bottom .. that combined with the penetrating oil from the top should work ... if not, a little heat would also help.
Thanks guys i think ill have to sacrifice the dropper but is what it is best regards
Clamp a big ass pipe in the seat clamp amd use it for leverage to start twisting it from there you can spray penetrating oil on the collar amd continue to twist and spray should come out fairly quick I think
Put the post in a vice, and wiggle it . We've found this to work most of the time. Best done if you strip the wheels etc. Have the bike upside down in the vice. Vice secured around the post and wiggle wiggle.
If you are in cape town (on my mobile so can't see location) give Woodstock Cycle Works a buzz/email
Are you sexually frustrated bro?
hahahaha Penetrate from the bottom?!
Bit of lube can do wonders if things get tight ..........
