https://www.mtbr.com/threads/xt-m8000-broken-pistons.1056556/
I got some hardly used looking XT785s (?) from a friend of mine. He had replaced them a while ago but gave no details on what was wrong with them. After a long a tedious bleed process on the front brake, I eventually got normal feeling lever pressure and some brake force up front. Unwisely perhaps I took them for a test on my enduro bike. This involved some 50kph plus rough descents. I survived but noticed the brake power seemed about half of my much older SLX brakes on my other bike and less than the Guide R I had just taken off.
I bought some new pads and tried to fit them to find one of the pistons seemed to be jammed out. I decided to strip the caliper and found pretty much what the guy in the MTBR thread above found. The pistons had shattered from the inside and made a crunchy sound when pressed on and the one leaked a bit.
My older SLX brakes are by no means perfect but have not developed this kind of terminal issue, yet. The XT brakes in question had seen duty on a marathon bike and may have done some Epics. Still, I can't imagine why a ceramic piston would shatter from the inside.
The takeaway i got from that was...Where did you find 50km/h rough descents? Share ! :D
Usually it's because the pistons have been forced back in skew at some stage. Piston jams against the gland, gets forced in, chips, then cracks.
Replace caliper is your safest bet - usually the sharp edges will cut the piston seal so even a new piston will leak if you can find one. And considering the only place you'll find a spare piston is in a caliper, this is not a hard decision.
You should find used calipers with a wanted ad, dead levers are far more common. And all Shimano levers and calipers are cross compatible.
Ha ha  - there are a few short steep sections in Cecila, Lower Kirstenbosch and the Green Belts where you can top 50, while being very careful of people and dogs of course.
Thanks, yes I have a replacement caliper already and have a front brake up and running.  What seems to be a harder job is finding a long piece of hose with a banjo attachment on the end... Not even Shimano seem to have stock.
Fast, yes.  Fast and rough?  Not so much  :ph34r:
It depends on your definition. I call anything with loose baby heads, loose corners and ruts "rough" and there are plenty of segments like that around.
I may have spares if you can send me a pic of the hardware you need
Thx, right now all I need is a 1.7 m plus length of brake line with a Shimano banjo fitting on one end.
And here I was hoping you meant singletrack/trails :(
So Pat's is still the fastest rough trail you can get ... possibly in the WC? hmm
There are some bits of single track in the mix but they are short and over very quickly at speed. Pats is on another level of course.
