My Fox Fork keep loosing air pressure. Replaced the O ring seal at top, lasted for about a week now flat again. Tried to spray soapy water in order to find where air is escaping without success.
Some advice will be appreciated
Which fox fork is it to start with.
Could be one of a couple of seals or even the valve if it's loosing air. The Tala versions sometimes also collapse without actually loosing their pressure, the air leaking into the talas section rather.
Full service with new seals all round should fix though.
