Drivetrain road bike conversion
TCTG
 Share
13 hours ago, TCTG said:
Yes a worthwhile option to consider but not sure if the jump from 52 to a 36 may create problems. I suspect that I will need to change the big blade as well... basically change over to a compact crank.
Why? It's a perfect solution to your problem and you don't have to fiddle with derailleur hangers and what not.
Quote
I have a 52/36 up front and an 11-28 rear cassette
https://www.trainerroad.com/forum/t/bike-gearing-suggestion-52-36-11-28-want-slightly-lower-gear-s/41613
Is literally the first result when googling "running 52/36 chainrings"...
Edited by TNT1
Link to comment
Share on other sites
I recently did exactly that, slapped a new 11 speed 52/36 Crank on my 10 speed bike. And then got a 11-28 10 speed cassette. Must say I'm very happy with the range.
I've actually got more range than I had on my Compact crank and the 11-25 cassette both ways.
Edited by PappaWatTrap
Link to comment
Thanks this is extremely helpful and there are plenty options to consider. The link below may assist as well.
http://bikecalc-staging.herokuapp.com/speed_at_cadence
Link to comment
From my previous problem solving on the topic:
1. Typically you have to choose between changing the crank (or chainrings) on the 10s solution vs. changing the RD+cluster+shifters+wheelset to make an 11s solution work. A wide range 10s cluster isn't the best solution.
2. ..because - you want to retain reasonably closely spaced gearing on your cluster - if you go to 11-32 or more you may find the gears a little too long between shifts. 11-28 is nice.
3. best up front is to go compact. 50/34 or 50/36. If you're struggling on the low end, you're not going to miss the high end gears from a 52 front ring much.
Link to comment
Sign up for a new account in our community. It's easy!
 Share
My Profile My Forum Content My Followed Content Forum Settings Ad Messages My Ads My Favourites My Saved Alerts My Pay Deals Settings Help Logout
