Jaco Greeff Posted October 26, 2021 Share HI All Where can I get a front pannier / front rack for touring ? Link to comment Share on other sites More sharing options...
NC_lurker Posted October 26, 2021 Share If your fork has cage mount bolt holes then you could go the route I did and use dry bags attached to home-made brackets. Jaco Greeff, Zebra and 100Tours 1 2 Link to comment Share on other sites More sharing options...
Jaco Greeff Posted October 26, 2021 Share 3 hours ago, NC_lurker said: If your fork has cage mount bolt holes then you could go the route I did and use dry bags attached to home-made brackets. I have a fork with a shock, so no bolts, but this have me some ideas. Thanks NC_lurker 1 Link to comment Share on other sites More sharing options...
Dusty Posted September 22, 2022 Share Grant from https://www.cycletouring.co.za/ has some options. Link to comment Share on other sites More sharing options...
Fat Boab Posted September 22, 2022 Share Quite a useful resource on how to add fixtures which may be of interest...https://bikepacking.com/index/add-cage-mounts-bike/ Dusty 1 Link to comment Share on other sites More sharing options...
Michael Viviers Posted September 22, 2022 Share Hi..I just put normal rack on backwards attached to shocks with clamps and extra water bottle holders Dusty 1 Link to comment Share on other sites More sharing options...
Brakepad Posted September 22, 2022 Share The rack needs to be attached to the top /crown of the fork otherwise you will run into trouble sooner or later. your options might be: change to rigid fork, live with bad suspension/shortened lifespan or stay below 2-3 kg Link to comment Share on other sites More sharing options...
Register a new accountSign in
