does an erratic speed mean the battery is going? speed drops to about half at times, and then sometimes no reading
not sure cause i got a different wheelset on now, and the bike was in a knock
Check that your spoke magnet it within the range it should be.  I have found when cleaning my wheels, the magnet may move slightly and then on the next ride, my speed reads pretty much what you're saying.
I would check this first, then have the battery checked.
Could also be that the unit is not making proper contact.
Had an old Cateye 6 long time ago and the unit started this crap. Turned out the points were not making proper contact and so the reading was erratic.
check the size' date=' if your speedo is too small it might squeeze your family jewels and give you headaches.
hahaha....problem solved then LOL
Is it wireless? what frame are you riding' date=' I hear that some Polars dont transmit properly on full carbon frames[/quote']
not wireless and it's a alu frame
havent looked at it yet cause i decided not to use my bike for die burger
seeing that this is MY thread i think i'll hijack it...
i dont know the exact geometry of the trek 2300 i used, but it's a 58cm compare to my scott elite 56cm...
it's more comfortable and i can ride on the drops better.
but my back was sore after both rides i did on it.
now do i need to get used to the position or wot?
i dont wanna change the setup and i feel comfortable while riding
andre_ct2008-12-01 08:50:13
Could be that the cable is frayed - mine's just given the ghost for this very reason. It was worn away due to something (could have been caught on bike rack/when i removed wheel/whatever) but the wire was actually frayed and last week i was going downhill at exactly 2kph. Then a second later 58, then 24. And for the burger, no reading at all.
