I would think if you washed it, dried it and then soaked it why not... im sure these other things are all cons...
I tend to remember that my gocart`s chain thru mud and everything survived very well due to me using normal oil and back then I didnt even soak it...
Only thing is it makes a mess as it flys out the chain
I am no Chemical Engineer and what I say could be / is wrong?
The viscosity of oil depends on the operating temperature of that oil. So in an engine or gearbox, the optimum operating temperature is between (again a guess) 60-100 C and that's when the oil does it's work best.
These temperatures are not generated by your chain so therefore I would suggest you use cycling specific lubricants.
PLEASE IGNORE THIS POST AS I DON'T KNOW WHAT I AM SAYING!!Big%20smile
Viscosity of an Oilis affected by temperature and you are correct in saying that Motor Engine Oils are designed for high temperature continuous use,....However :)
At start up the engine is stone cold and at ambient temperature and the oil is lying in the sump. So when you turn the key the starter turns the crank shaft which turns everything else like the cam shafts. The cam shaft is bone dry at this point. The oils have additives called anti wear additives which are zinc phosphate based. These adhere to the metal pats to provide that barrier to metal to metal contact. These work best at low temperature.
A bicycle chain works at ambient temp and is slow speed so metal to metal contact is the norm. The type of oil i very relevant here because it would need to be more viscous to prevent the metal to metal contact. Some of the Zinc Phosphate stuff would be fantastic too.
So yeah you can say stick to a bicycle lube, but motor engine oil has all teh right ingredients to provide adequate lubrication.
wax lubes seal and don't splatter the bike with oil.
liquid Lubes penetrate and clean better and if they have the zinc stuff then they provide adequate lubrication and prevent metal to metal contact.
any of these will work:
Engine Oil
Gearbox oil
hydraulic oil above ISO22
3-in-1 oil
bicycle chain oil
darn you could use a 000  consistency grease
Really chain lube is not rocket science
Well, I dont know cos, I ran out of bike lube recently and since then I have JUST been hauling my dipstick out of my car on a regular basis and lubing my  chain with the car oil, in my opinion its all oil, how wrong can one go.
Well' date=' I dont know cos, I ran out of bike lube recently and since then I have JUST been hauling my dipstick out of my car on a regular basis and lubing my  chain with the car oil, in my opinion its all oil, how wrong can one go.
Eish!!
Rather go to a garage and dumpster-dive for an "empty" can of oil and use that. Your car's dipstick should ideally not be exposed to grit. You don't want to touch the chain and introduce grit into the sump.
Perhaps I'm stating the obvious. In all other respects, sump oil is fine.
Johan Bornman2009-03-20 06:29:10
Eish!!
Rather go to a garage and dumpster-dive for an "empty" can of oil and use that. Your dipstick...and your car's dipstick should ideally not be exposed to grit. You don't want to touch the chain and introduce grit into the sump.
I guess as long as you let it 'drip' on it's OK then .... LOL
Ja, but dipsticks don't drip much. You'll have to remove and replace it 112 (the average no of links in a chain)  times before your chain is oiled. By number 74 you'll be so tempted to touch and release more oil.
in fact, filtered sump oil works a treat too. Next time your car goes for a service, ask them to drain about 1L into an old oil container (take one with you).
When you get home take a sheet of newspaper and roll  it/ fold it into a cone.
Place this cone in a plastic bucket of sorts (preferably nothing the wife will use again ) and slowly pour the oil into the newspaper cone. The paper will filter much of the grit and the oil will be ready for use as bicycle chain lube oil.
The newspaper on the other hand should be disposed of properly or let it dry and use it as fire starters for your next braai.
oh yeah to lube the chain simply dunk the whole thing in the lube oil, swirl (don't drip on the floor please) and remove it. Now let it hang with the lube oil container underneath so the excess can drain back into the container.
cheap and eco friendly. Recycling is a practice that should be rewarded.
Lefty, with respect, this is crazy. Who wants to handle old oil? I also doubt that the newspaper will filter the oil in under ten days. By then the dog has pushed over the bucket and.......
Why do these oil threads always go downhill?
