could be a bearing or bearing casing that broke and is loose inside the hub, the noise then ecod by the rest of the wheel and spokes
What hubs are you running? Maybe an idea to strip them and check for loose bits / trashed bearings / any other random crap that could cause an issue
Hope Pro 3 hubs
but the pro 3 hubs are non-disk, think they are 4 roadies Smile also might be your freehub body that is shot. if sometimes you put pressure to pedal and it seems like the wheel does not engage...
