strange noise on front wheel
linton
For a while now i have noticed a wierd noise coming from my bike as i ride, I traced the noiseto the front wheel.
If i lean the bike to the right the noise stops, lean it to the left and it comes back, seems consistent enough to say that it occurs when a specific portion of the wheel comes under a specific load (these specific points and loads are unknown to me at the moment :\ )
It's a metalic type clink.
I'm riding on alexrims PC19.
Any help for this incredibly detailed problem Embarrassed
Link to comment
Share on other sites
Have the wheel checked out by somebody competent. It is most likely rough bearings but it is as good as diagnosing your cough over the internet!!!!!!!!!!
Link to comment
Do you ride with a racetec chip on the front wheel?
I noticed my chip rattles a lot...maybe the same thing?
Long shot, but thought i should mention it.
Link to comment
Then it's probably not been stress relieved properly. Take it to a wheel builder, he'll sort it out for you. Maybe PM Johan Bornmann, lord of all things spoke-y.
Link to comment
Then it's probably not been stress relieved properly. Take it to a wheel builder' date=' he'll sort it out for you. Maybe PM Johan Bornmann, lord of all things spoke-y that have nipples[/quote']
Link to comment
yea' date=' i do. but pretty sure it's not that ... I don't think.
The chip fits into an orange housing, but it is not super tight.
I found that mine was making a hell of a lot of noise.
Wrapped it in one layer of insulation tape, and it stopped immediately.
Try it, its a cheap quick fix that hopefully resolves the issue, if not, then pursue other options/problems.
Maybe you are lucky.
Link to comment
carefully remove the little sparrow wedged between the left brake caliper and the rim, if the beak is touching weird noises can result.
alternatively let Johan B take a look at your wheel bearings www.yellowsaddle.co.za
Link to comment
My expert opinion: Your bearings are poked.
Sorry, can you cough again?
Get it checked out ASAP before the whole hub is damaged beyond repair. I speak from experience.
Link to comment
indeed, it's at a specific point of rotation. and only if the wheel is experiencing force from one specific side.
Link to comment
Can all the Hub Bicycle Practitioners gough together again please????????....... Linton..... listen to the Oom of the Hub!!!!!!!!
Link to comment
indeed' date=' it's at a specific point of rotation. and only if the wheel is experiencing force from one specific side.  [/quote']
Two suggestions:
(i) pedal evenly
(ii) Check your knee-replacement. It might need a squirt of Q10.
Link to comment
