Hi all
I was wondering which is the best place to buy some nice long sleeve winter cycling tops from. Best priced that is.
In the Gauteng area, also could you furnish a phone number please.
Thanks in advance Smile
Hmmmmmmm, depends where you are located ?
In Pta try one of the following two:
Fritz Pienaar cycles 012 362 8816 - They have local and international brands
Elsa Karsten Cycles - 012 808 1880 - They have local and international brands
In Jhb area:
Cajees Cycles 011 894 2020 - They tend to stock the more affordable stuff
Why not look at the long sleeve moisture wicking tops such as Helly Hansen.
All good canoeing shops stock them.
They are not warm enough on their own. I did wear my Due South under my long sleeve Cape Storm "summer" top with the night ride and it was fine, but it will not be forearly morning rides. You want something inbetween arwarmers and jacket.
Does anyone have a number for westdene and an address please?
sory, don't know it by heart, but where you from maybe i can help you get there if its not too far
sory, found it.
westdene cycles: 13 Perth Rd,, 011 477 5735. or maybe
Westrand Cycles, Wilropark, 29 Voortrekker St, Mindelore,
011 955 4342 ...
I am located near Fourways. Directions from corner of Witkoppen and william Nicol will do fine.
Take N1 south. Get off on Gordon Road. Turn Right over the highway. At the lights at Hendrik Potgieter turn left. Continue untill you get to the light at Ontdekkers road. Turn left and continue through alot of traffic lights. You know you are still on the right track if you find Philips on your left. Continue a few more lights untill you will find them on the left.
Clothing should be bought from your LBS, but haggle them as far as possible. That way they'll keep smiling when you visit and forgive you for buying your equipment at the best-priced shop.
