A question,
Is there a formula to calculate average watts on a climb if you have the following.
Ave speed
Energy expenditure
Gradient %
Total Distance
total Time
Any of the Boffins out there know how to do this? Maybe someone doing highschool science?
OK, here goes:
x(squared) * y. Then deduct C after multiplying that with the sum of A+B.  Remember to divide Z into the result.  If you then find a good answer. let me know, 'cause I have NO clue what I just said!!!!
Don't think school science covered that detail. I remember something about calculating the power it would take to lift an object a specific height. The formula was something with weight , the time it took and the height. Or may I'm missing the pot completelyLOL
Don't think school science covered that detail. I remember something about calculating the power it would take to lift an object a specific height. The formula was something with weight ' date=' the time it took and the height. Or may I'm missing the pot completelyLOL
You've NEVER had the plot!!!!  How the hell do you want to loose it now?
... but on the other hand ewep' date=' I know that it take much more power to take you up a hill than meLOLLOLLOLLOLLOL
But at least I make it to the end of my MSD's (MEDIUM slow distance)!!! Big%20smileWink
The calculator is Brittish, a bit confusing, what is the inches diameter for a normal road wheel?
How many cm in one inch, Kg/Lbs, and km/miles?
ha, but did you tell that I've been training only for 5 weeks before that...Star
OK, thanks for the replies, what I wanted to check was my ave Watts on the climb on the Kremetart first stage as per the Data from my Polar:
Duration00:15:00
Average Speed 22.0km/h
Distance 5.6 km
Grade %5.0%
Worked out to between 310=320 watts on average
RABUBI, go to www.machinehead-software.co.uk you can download a good software kit from there to let you do power calculations.... Their power calc works on similar algorithms to i-bike... similar variables etc...
