After a race this weekend my front and rear pads of my HOPE TECH X2 brakes needs to be replaced. I found some on buycycle, but it's the sintered version. Hope says that the sintered version is not recommended for dry conditions. On crc i can get sintered or organic. Whats the difference?
  • Replies 45
avid sintered or hope sintered or whatever, it's all the same until once the pad hits the rotor. I only ever use sintered metal and it works in all conditions.
The organics i've heard tend to be a bit sketch in the wet.
this is off buycycles website.
Top Features of the Hope Sintered Pair Of Brake Pads
•Made by EBC
•Longer lasting than standard
•Heat up more than standard
•Good for winter or wet weather
•Not recommended for dry conditions
This sounds like a money making thingy. Motorbikes pretty much only use sintered in all conditions. Mud/MX/desert included.
Edited by TNT1
i thought so as well. but i think im gona go to crc for this, pads cost R110 per pair there. Here it costs R260.
Sintered heat up quicker. So if u one of them XC lads who sits on the brakes the whole time, you gonna get fade.
Organic = 1 ride in wet an muddy and you are in for new pads.
You decide.
it's not the pads, but the friction-induced heat caused from prolonged braking. The heat transfers to the hydraulic fluid (if u have hydraulic brakes) and causes air bubbles to form. Air bubbles are much more compressible than the hydraulic fluid, and causes your brakes to feel 'spongy' that is to say, it will lack proper feedback between pulling on the lever and the expected braking effect...
Edited by Jarek Wysocki
I replaced my original Hope organics with metallic (sintered) and they are great. They take longer to bed in, can squeak when they are wet, but they work in all conditions. I've just come down the mountain at Mankele and they were strong in stopping, when I needed them to. I will also be putting sintered pads in my Mini Mono's on my 29er when the current pads are worn out. Check out the orignal Hope pads as they are not much more than the generics.
why would the sintered pads cause the brake to fade?
Heat can cause fade.
Fluid fade, when the brake fluid boils, the air in the fluid compromises the pressure.
Pad Fade happens when the pad overheats and loses friction through glazing etc.
Pad fade can happen on organics too when resin 'boils' out of the pad.
Sintered metal pads are a good in-between. If you are riding XC on 160 rotors go that route.
Organics bite nicely, work well for DH and large rotors, wear quickly, and are crap in wet and muddy conditions.
Can I throw my hat into the "hydraulic fluid heats up too much" ring? How hot do these brakes get? How hot do the brakes on my motorbike get? Can we get something behind all this?
I use dot 4 race on the motorbike, can I use that on the mtb? It will destroy seals, wont it? I have to use mineral oil, don't I? I think the marketers saw you lot coming a mile off.
And this happens with the fun riders on this forum? Holy F*%k!
