CRAMPS: The clearest view I've read yet...
From cyclingnews.com:
http://www.cyclingnews.com/features/cyclingnews-fitness-q-and-a-june-1-2011
What is a cramp?
[Cramps are strong, involuntary muscle contractions. They can occur at any time but are most common during or shortly after hard exercise. They can occur in any muscle, though in cyclists they are most common in the quads, hamstrings and calves. They can be so strong that they cause you to launch out of a chair or actually pull a muscle.
Cramps have many causes, though fundamentally they are similar. When you move, your brain sends signals to your muscles requesting a contraction. The brain receives feedback on the strength of the contraction that has occurred, from which it can make adjustments to create a controlled movement. If the feedback says that the contraction is harder than expected, the brain can send instructions to contract less. If the feedback says the contraction is weak, the brain can send a signal to contract more. As a muscle fatigues, the brain sends more signals to tell the muscle to contract to get the same strength of contraction. When the muscle becomes too fatigued to do what is asked of it, the brain sends a continuous contraction signal, initiating a cramp.
Causes of cramps and how to correct them
Anything that fatigues a muscle can bring on a cramp, and anything that keeps a muscle fresh helps prevents cramps. Talk to your coach about which of these might be your particular problem.
Inadequate training: You may cramp late in a long or hard ride simply because you have not trained adequately for the distance or the intensity. Make gradual increases to volume and intensity.
Pushing big gears: One clue that you may be doing this is if you find yourself standing each time you need to accelerate. Another clue is measuring your cadence below 85 rpm for much of a hard ride. The cure? Switch to a lower gear. Spin to save your legs. Get a larger rear cog or a compact or triple crankset if necessary.
Dehydration: Muscles don’t contract well if they don’t contain their normal amount of water. Stay hydrated.
Fuel: Muscles can’t contract if they don't have a good supply of glucose. Keep eating carbohydrate rich foods on longer rides. Eat something at the start of the ride, after about 30-40 minutes and every 15-20 minutes thereafter. Aim for about 250 calories per hour if you are under 150 pounds and 300 if you are over 150 pounds.
Electrolyte balance: Muscles will cramp if they don't contain their normal amounts of sodium, potassium, calcium and magnesium. Those amounts change during exercise. Salt your food and eat plenty of bananas. If you don't eat a lot of dairy, take a calcium supplement or eat plenty of brassica veggies (collards, kale, cabbage, broccoli, Brussels sprouts and cauliflower).
Calcium: Calcium-based antacids such as Tums have cured many cases of cramps. Take one before riding and one each hour of the ride if you've been cramping. Don't wait for the cramp to take the calcium.
Raw Spinach: Some leafy green vegetables eaten raw, particularly spinach, will leach calcium from your system. Avoid large amounts of raw spinach. Cooked is okay.
Creatine Monohydrate supplementation: In some people creatine supplementation (especially loading) may cause cramps, especially if the athlete is dehydrated. If in doubt, avoid this supplement.
Tight muscles: Regular stretching of muscles that tend to cramp sometimes reduces cramping.
Impaired circulation: Muscles that are not receiving adequate blood supply are deprived of oxygen and fuel. They will not recover from one contraction to the next and so will fatigue quickly. Correct pressure points on the saddle, in your shoes, in your shorts and anywhere else they might interfere with circulation.
Heat or cold: On hot or cold days some people will cramp even if they do everything else right. On hot days, do what you can to keep cool. As well as staying hydrated, dribble water on your jersey and shorts and through your helmet every once in a while. Choose shadier and flatter routes on hot days, unless you are racing and don't have a choice. On cold days, dress warmly.
Bike Fit: A poorly fit bike may cause some muscles to work harder than necessary, bringing on a cramp. If in doubt, have your coach check your fit.
Rhabdomyolysis: If cramps are followed by red or brown urine, you are experiencing a breakdown of muscle tissue and release of muscle contents into the blood. This is a medical problem needing immediate professional attention to prevent kidney damage. Treatment for acute rhabdomyolysis is high volume IV rehydration.
  • Replies 76
Brilliant. So simpletons like me can understand.
Train more
Drink water
Eat stuff.
Brilliant. I have hit the REPORT button (to alert a MOD) so that THE POWERS THAT BE can Sticky this to the top of the WorkHard&Eat page. :thumbup:
For sure.
Remind me again when my memory cramps up, Swissvan... :huh:
Hmmm nothing in the artical about memory cramps.
Maybe try some dextrose sweets or pin the thread
Guest Frail4Life
@ Airbender
IF you were Base training with me, you will NOT get Crampsss.
HE HE
I dont struggle with cramps, but read this article last week.
Lo and behold at Hazeldean - started cramping on 6KM!!!!!! :o
So the obvious question is: does the temp affect this? Also, what is the best remedy to cope with cramps during racing?
eben, i am of the view that you only started cramping because you read the article. Cramping
is all in the mind..... Just got a brain cramp....oh, never mind
  • 1 month later...
I heard about quite an interesting "cure" for cramps last night.
My sister-in-law's husband's (how the hell do I put this otherwise??) came back from doing the Tour de Tule (he's from th USA) and told me that probably the best thing for cramps is the juice in a bottle of pickles. Thats what he uses and it works immediately. Probably due to the high sodium content.
Gonna give it a go and take a small bottle of this along in future long rides.
One other remedy he mentioned is that mustard you normally get with take-aways, but that one would be hard to swallow I think.
What do u guys think?
Guest agteros
Good read. Cramped badly in the quads in the Argus. Its a print and re-read...
Why do you want to sacrifice a tree? The blue people will get upset :(
