Hi
I want to upgrade my current entry level coil shock to an air shock. I've developed shoulder and wrist pain and this can be because of me being a little heavy on my shock. (according to my LBS)
So i am looking at a second hand shock (due to economical times). How would i know if a shock would fit my bike? I have a 2011 GT Avalanche large.
I see you get tapered and obviously there will be different lengths of the shocks, how do i know what to look for to replace mine. (without taking my bike apart and checking?
Thanks,
Cobus
Hi
Me thinks you need a new LBS, with a story like that they have spent too much time in the Local Bottle Store
Ja i spoke to a kid in the shop so not too sure how true it is but i guess it wont hurt upgrading the shock anyways from an entry level coil...
Some softer grips might help as well (they did for me).
As to what to check for in a new fork... you would have to check if yours is tapered or not and try and measure your current fork's steerer length.
I wouldnt replace anything as yet, shoulder and wrist pain could be due to setup... have you had a proper setup done before?
A nice air fork is always a good upgrade and makes the world of difference to handling but one thing for sure is dont blame the fork for the shoulder and wrist pain.
Are you not reaching a bit too far perhaps? How tall are you being on a large frame?
jy slaan die spyker op sy kop - im 1.85 and ive already had to put a 400mm seatpost on - next step adjustable stem...but i've heard from two bike shops that my bike is too small for me - cant afford a new one so i have to make do...
is there a way to see if it is tapered without taking apart?
1.85 is fine on a large.
First thing I would do is make sure the bar is angled correctly. If set wrong your wrists are strained and on long rides will fatigue a badly.
Next is to make sure your fork is set correctly. Reduce the preload all the way. Loosely attach a cable tie to the one stanction and get on the bike into your normal riding position. dont compress the fork.
Get of the bike and see how much the fork sagged. It should be around 15 to 20% of the total available travel. If more add more preload until the correct sag is achieved.
Most forks will allow you to adjust the rebound damping. Too slow and the fork wont decompress fast enough to get ready for the next bump. Too fast and the fork will pogo a bit also reducing its ability to absorb bumps correctly.
Next up you can look at thicker or thinner grips depending on how big your hands are. ESI Chunky grips are awesome and absorb a lot of the trail shudder too fine for a fork to absorb.
Check tyre pressure on the front.
thanks ill check how far i can get with these
A tapered one will be wider at the bottom than the top, google for some images and you will see the difference. I'm taking a guess, but yours should be non-tapered on that model bike.
If you don't know the make of fork and cannot google it to find out the specification of whether it is straight or tapered, then look up you bike on www.bikepedia.com and it will give you the full spec of your bike, then you can find out more about your front fork.
You can then also find info on how to set the front fork up
schweet thanks!
got this from the website:
XCM V3 HLO 26"
Recreational trail riding
• 120mm / 100mm / 80mm
• Coil spring
• Mechanical lock out
• Hydraulic damping
• Alloy bottom case
I.C.E.
N/A
Travel
80 or 100 or 120
System
Coil spring / Hydraulic Remote speed-lock
Lower
New alloy monocoque
Design
Leading axle
Dustseal
Metal inserted type
Leg Color
Gloss black, Matt black, White w/ heat transfer type decals
Crown
Alloy
Pitch
130mm
Integrated HD
Semi ID type / 44mm
Stanchion tube
STKM
Stanchion tube finish
CP finish
Finish
Black
Right Side
Hydraulic lock-out cartridge
Left Side
Coil spring
Steerer tube
STKM
Length (w/o thread)
255
Crown race diameter
30
Wheel size
26"
Brake
Disc (Post mount type: for 160mm direct mount) & V-brake type
Preload adjuster
Yes
Diameter
30mm
Note
Disc only type bottom case available
Weight
2650g
max. disc diameter
185mm
Go for a proper bike fitting
If pain still persist go and see a physiotherapist to evaluate your shoulder problem. It may be something that could be sorted out with a bit of proper stretching or development of the correct muscles you may find a more sustainable solution to your problem.
If you cant afford a new bike you will find upgrading your fork not a very economical option either. You will undoubtedly find it cheaper or similar to get a correct sized frame and work on your posture/strength and get set up properly.
second third fourth,
get a proper bike fitting done like ergofit.
G
