Shimano introduces carbon Dura-Ace crankset
http://www.bike-eu.com/public/Image/Bike%20Europe%20Website%20Dura%20Ace.jpgAt Eurobike Shimano introduced a carbon fiber Dura-Ace crankset. The FC-7800C has an aluminium core to realize a lightweight yet very rigid construction. By using this technology, Shimano developed a crank set that combines the best of both materials.
The aluminium frame ensures a stiff set-up for optimal power transfer while the carbon saves weight. In numbers: weight of this crank set (including bottom bracket) is 709 grams and it is 10% stiffer than the aluminium Dura-Ace crank set FC-7800 that is already famous for its rigidity.
FC-7800C has been developed with Shimano?s proven HOLLOWTECH II technology with an integrated bottom bracket. It uses identical bottom bracket bearing cups as FC-7800. The left crank arm features the same installation technology as current Shimano XTR to save some weight and to make installation even easier.
This state-of-the-art crank set will be available in gear combinations 53/39T and 52/39T in crank arm lengths 170, 172.5 and 175mm.
Michael Boogerd (Team Rabobank) and Markus Fothen (Team Gerolsteiner) have taken this crank set already to the ultimate test: the Tour de France. The crank set will be available as after market product from spring 2008.
So who is going to get this????Big%20smile
And so we say goodbey to the last great alloy crank. I think the DA alloy crank is one of the best ever made. Carbon suck...
Have a look at this part: The FC-7800C has an aluminium core to realize a lightweight yet very rigid construction
I know. Did some research on the development. I still think the alloy one looks better. And no cyclist will ever feel the 10% improvement in rigidity.
Now the kempekkers will say that Shimano copied the use of carbon fibre from them...... watch this space some dumb kempekker will make a silly statement again or start his own shoulder slapping posting. They are all so predictable.
It looks good but would have looked better if they did not make it with the weave pattern but rather the fibre pattern that Campy/Fulcrum has got.
Looks like Shimano copied Campag... Tongue
Oh dear, here we go again. Lighter, yet stiffer. Stiff, yet compliant. Carbon, yet aluminium.  Like Campy, yet with a twist. Silver, yet black. New yet classic. Expensive, yet worth it.
Isn't marketing speak wonderful? I wonder what "optimal power transfer" means and how they've managed to optimise this over a 1930s Stronglight steel crank or indeed, over the crank fitted to a child's trike.
For the 31g saving over the std DA cranks' date=' I'll stick to my std units too.
I WANT ----NOW ! where can i order from ?
$1400 pre order on competative cyclist:
or a little better at ?510.63 on chain reaction cycles:
As much as the crank looks quite cool, If I was going to be a weight weenies, there are plenty lighter cranks out there for less
If I have a look at the pictures of the disection of the crank it strikes me as though the carbon is really just a cover for the metal below.
Oh yes I agree with greatwhite, for 31 grams, I stick to my current DA thanks. besides, I will just have to remember to go to the toilet before I go and ride. There you go, 31grams saved...
