Why is it that most people change their ss gearing by switching sprockets? I find good quality sprockets hard to come by whereas chainrings more common and actually cheaper.
Is the chainlength affrected more by varying the chainring size?
  • Replies 42
2 mins to change sprocket. 10 mins to change chainring. That's my take. Sprockets on CRC are a dime a dozen. Way cheaper than chainrings...
Locally sprockets are going for R300 plus. I'm talking decent wide ones and not just the plain punched steel. My fancy hubs are new and I dont want to damage the freebody.
Unfortunately decent sprockets are expensive.
I brought some in from http://velosolo.co.uk/shopsingle.html over Christmas. So if you know of anyone coming over....
What gear ratios do most of you use?
I run a 32 chainring front, and vary the sprocket 16 or 18. With 16 i find some climbing just too tough, but with the 18 again the climbing is fine but then i spin out on a flat road. .
Its always a bit of a compromise.
Depends on the route, as well as your strength.
Most common i have come across in my own personal market research ( asking peeps what they using) is 32 18
Guest Latent Blue
Thx for this. Still curious what ratios you guys run?
32 / 17-19 (29er)
Edited by Latent Blue
